Best Exhaust System?
Old Oct 29, 2002 | 07:55 AM
SpiritR's Avatar
Default Best Exhaust System?
Just wondering what's the best exhaust system, performance and sound wise?
anyone considering the hks tit?
Old Oct 29, 2002 | 07:57 AM
Chris N's Avatar
Default Re: Best Exhaust System? (SpiritR)
Search.
Depends on your application, also. To some loud as fawk is heaven, to others its just plain dreadful. There's no one 'best' exhuast system, probably a handful of realy good ones, though.
Old Oct 29, 2002 | 08:04 AM
mafay2's Avatar
New User
Kakimoto GT1.0Z
SMSP
Hytech
Old Oct 29, 2002 | 08:06 AM
Reid's Avatar
Global Moderator
Get the exhaust which has the look and sound you would like to have.
Don't get caught up in needing the "best".
Chris N's Avatar
Default Re: Best Exhaust System? (mafay2)
Ok, if we are going to name all the good exhausts...
Mugen Sports exhaust (aka twin loop).
Old Oct 29, 2002 | 08:19 AM
Brian's Avatar
I currently have and recommend the Mugen Twinloop. It is just a bit louder than stock and performs very well for me.
Old Oct 29, 2002 | 08:23 AM
owen_the_soyboy's Avatar
Spoon/Toda header, catjack, straight piping routed under the subframe to a N1 muffler from Apexi/Spoon/etc.
that is the most power providing setup.
but you may have other things you demand from an exhaust like it should be quiet or pretty... or even legal
Old Oct 29, 2002 | 08:38 AM
SRV's Avatar
SRV
Spoon 4-2-1 Header +Spoom N1 + Spoon B-Pipe =
Old Oct 29, 2002 | 08:40 AM
Reid's Avatar
Global Moderator
Default Re: Best Exhaust System? (SRV)
Do you have any dyno results or pics of your setup with these parts?
Old Oct 29, 2002 | 09:41 AM
Big Phat R's Avatar
The Mugen header/twin-loop exhaust is good for over 200 whp and is quiet. But it is heavy and has a very mellow sound (not for everyone). It has somewhat reduced ground clearance due to a very large central resonator. It also has a couple of "bottlenecks" that people seem to think makes it restrictive. Fit and finish is second to none.
The Spoon N1 is also good for over 200 whp and is very loud (no silencer). It has the advantage of being light but requires an aftermarket b-pipe (like the Type One). The flange of the N1 is still 2.25" (or smaller?) and requires modification to be a true 63 mm through and through system.
SMSP is a custom 2.5" system that looks and sounds awesome. The header is very long and requires a custom b-pipe. Should be good for well over 200 whp. Less expensive than the Hytech. Requires welding (usually). Also has excellent ground clearance.
Hytech is also a custom 2.5" system. The header has anti-reversion chambers and also is very long. Requires custom b-pipe. Very expensive and very difficult to presently get (very long wait times). Designed as a bolt-on.
The new Type One (T1R) is supposed to be 63mm through and through (no bottlenecks). You can get a SS or Ti muffler. Sounds great too. See A&J for details
[Modified by Big Phat R, 10:55 AM 10/29/2002]
Old Oct 29, 2002 | 09:52 AM
AJ PwR's Avatar
Best for what setup though ?
Old Oct 29, 2002 | 10:37 AM
mantic6t9's Avatar
Default Re: Best Exhaust System? (AJ PwR)
Is this true?
Old Oct 29, 2002 | 10:46 AM
disordeR's Avatar
Default Re: Best Exhaust System? (mantic6t9)
mugen tiwnloop for sound
T1R for bang for buck
SMSP or Hytech for power
Old Oct 29, 2002 | 10:50 AM
Big Phat R's Avatar
Is this true?
<from A&J Racing website>
T1R exhaust systems are 100% SUS304 aircraft stainless steel with 63mm ID (for NA), 76.3mm (for FI application) and 1.2mm tube thickness to ensure enough exhaust flow to bring performance to the limit. Specifically designed for mid-range to hi-rpm power. Applications: Honda EG, EK, DC2, DC5, AP1. Usually Stocked
Old Oct 29, 2002 | 10:52 AM
Back in Black's Avatar
Rather OG
Header, straight pipe, turn down.
[Modified by Jason Franza, 3:49 PM 10/29/2002]
Old Oct 29, 2002 | 11:33 AM
AJ PwR's Avatar
Yes specifically for cat-back systems only.
Old Oct 29, 2002 | 11:53 AM
mantic6t9's Avatar
ok well i was planning on getting the T1R b-pipe i supose it still has the bottle neck then.
gonein60seconds
Dec 21, 2010 11:17 AM
TunerFreak24
22
May 26, 2010 11:22 PM
Toptul_Honda
10
Nov 9, 2002 01:41 PM
Turbo R
Oct 14, 2002 02:18 AM
ASNG
Jul 22, 2002 11:25 PM
