z6 trans internals fit in b7 casing?
I have a z6 trans with good gears and a bad bearing, so I'm going to have to open it. Also, every single damn bolt hole on the outside of the casing is stripped out. can I put all of the internals in the b7 cassing at the same time without any modification? gear sets, diff, etc.
Thanks.
Thanks.
Odd...I managed to put Z6 internals into my CX case without issue. I swapped out the main/counter/final drive ring and it has been fine for the last few years.
Ef4doorwagon
Mar 1, 2014 09:43 PM
Linked
Nov 16, 2009 10:07 PM
