2000 Accord Rotors Secured by Axle Nut?
Old Feb 24, 2014 | 08:32 AM
Raiha's Avatar
Default 2000 Accord Rotors Secured by Axle Nut?
Hello, everyone,
2000 Honda Accord. Tried to replace my rotors this weekend but I just couldn't pull the darn thing off. After carefully examining the rotor again, it looks like the rotor is being secured in place with an axle nut?
Is this normal? All the places I've read said to remove the screws and the rotor should just come off.
Old Feb 24, 2014 | 08:57 AM
cptbarkey's Avatar
Default Re: 2000 Accord Rotors Secured by Axle Nut?
hit it with a sledge hammer. it *shouldnt* be cative to that axle nut, no.
Old Feb 24, 2014 | 01:44 PM
hondamark35's Avatar
the moderate build up of rust is hiding the seam between the rotor and the hub. the small OD "pilot" collar just around the axle nut is what centers the rotor and is part of the hub, but it is not part of the rotor.
see the threaded holes on the "hat" of the rotor? their purpose is you help get the rotor loose. put an M6 bolt in each and incrementally tighten them. they will push the rotor off of the hub. soak in plenty of penetrating oil before hand, and to go the extra mile dab some anti-seize on the bolt threads.
Old Feb 24, 2014 | 05:42 PM
holmesnmanny's Avatar
also if you look at the new rotor u will see where it goes and will see the axle nut doesnt hold the rotor
Charlie Moua
Jul 1, 2013 10:04 AM
Atheist
Jun 7, 2006 04:03 AM
1998hondaaccord
Mar 14, 2004 05:57 AM
Ill
Nov 11, 2003 07:26 AM
dynamo
Mar 25, 2003 09:06 AM
