93 civic auto with 2000 y7 longblock swapped. No spark/starting.
Old Feb 24, 2014 | 08:23 AM
Marvin1985's Avatar
Default 93 civic auto with 2000 y7 longblock swapped. No spark/starting.
I have a 93 auto civic hatch and swapped in a y7 longblock in. Used the stock d15b7 dizzy and intake manifold. New tune up parts. Not getting spark. Need to move car ASAP. All stock automatic car.
Advise?
Pulled plugs smell like fuel and are wet
Old Feb 24, 2014 | 09:42 AM
Marvin1985's Avatar
Default Re: 93 civic auto with 2000 y7 longblock swapped. No spark/starting.
Just tried a new main relay nothing.
Old Feb 24, 2014 | 10:10 AM
Former User's Avatar
What ECU? What head is on the Y7 block?
Do you hear the fuel pump prime?
Any CEL codes?
Old Feb 24, 2014 | 03:27 PM
Marvin1985's Avatar
No codes pump primed and plugs smell like gas. B7 stock ecu. I pulled the plugs and tested for spark after cleaning grounds. Bright white.
After some triple checking I'm coming to conclude that timing has jumped a tooth because my buddy stupidly rotated the motor clockwise...... Ugh. I'm gonna pull VC and check timing and reset it.
It's a unmolosted y7. All stock
Old Feb 24, 2014 | 03:35 PM
NotARaCist's Avatar
I never narc'd on nobody!
Are you using the D15B7 injectors, or the D16Y7 injectors? When you say "no spark", did you use a spark tester, or are you just assuming there isn't any spark because you're getting fuel?
Old Feb 24, 2014 | 03:40 PM
Marvin1985's Avatar
I have spark and fuel. I was WRONG. I thought I had no spark. Tested it and it's bright white.
Recap on setup. All d15b7 auto parts on a complete head and block d16y7. D15 alt,dizzy,mani,header,injectors
Old Feb 24, 2014 | 03:44 PM
Is the head b7 or Y7?
Old Feb 24, 2014 | 04:48 PM
Marvin1985's Avatar
Y7
Old Feb 24, 2014 | 04:50 PM
So you have a Y7 engine. To my knowledge, you would need a Y7 ECU and distributor. I'm not sure whether a Y7 base map chip is available for an OBD1 ECU. The swap gurus will surely chime in.
Old Feb 24, 2014 | 04:56 PM
Marvin1985's Avatar
Can't chip it cuz automatic. D15 dizzy bolts up no issue. Also last I searched the timing map on d15b7 and d16y7 were either same or soo damn close it's like a twin brother. I just need to check the timing and adjust. I'll post up results later
Old Feb 24, 2014 | 04:59 PM
okeedokee...I'll be interested to know if what you say is verified by others.
Old Feb 24, 2014 | 06:37 PM
nub's Avatar
nub
It sould run fine if what OP stated is correct as far as head, block, injectors, distributor and ecu. The B7 distributor bolts up to the the Y7 head.
A couple of things off hand is the Y series run with 12* ignition timing and the B7 is 16*.
Check the valve lash to make sure it's not too tight bleeding off compression.
Double check you have the spark plug wires in the correct firing order.
Old Feb 24, 2014 | 07:13 PM
Old Feb 26, 2014 | 12:36 AM
eghatch9295's Avatar
Stancetard Hate Monger
b7 distributor/ecu work just fine on the y7, i have used the combo personally. what happened with the timing?
Old Feb 28, 2014 | 07:53 PM
Marvin1985's Avatar
Got it running. Timing was off a tooth. Just gotta get it cleaned up and make other repairs to random stuff and it'll be a fully stock and clean hatch for the DD.
GarageNut
Jul 1, 2012 10:16 AM
rareturbobreed
Jul 19, 2011 03:27 PM
kubcha
Oct 23, 2010 09:50 PM
fcluddington
11
Sep 24, 2009 09:50 PM
