Valve Cover Gasket
Old Oct 29, 2002 | 07:38 AM
KOALA YUMMIES's Avatar
Default ..
Old Oct 29, 2002 | 07:42 AM
Nameless RB26's Avatar
Default Re: Valve Cover Gasket (NOINTEGReddy)
Don't worry about it... re-use it.
Old Oct 29, 2002 | 07:57 AM
EP3_05's Avatar
Yeah, you can reuse the gasket.
Old Oct 29, 2002 | 10:25 AM
Eluzion's Avatar
Default Re: Valve Cover Gasket (91civic)
Where do you apply the Honda Bond? I'm going to be doing a valve adjustment this weekend. Only part I'm not sure about is the valve cover:
Could I reuse my stock gasket? I'm guessing not.
Do I need to replace the rings around the spark plugs as well?
What areas do I apply the Honda Bond?
Should I use a torque wrench for tightening the valve cover bolts? (I know it's only 7.5lbs, was thinking of just using hands and tighten very lightly).
Oh and one more thing, do I really need angeled feeler gauges? I can't find any .003+ angeled ones, just regular.
I did a search, spent over an hour reading just about valve adjustment topics yesterday in class (had nothing to do lol). I was getting mixed answers about the valve cover gasket and tightening the bolts on the valve cover. Thanks.
Old Oct 29, 2002 | 11:25 AM
Achenar's Avatar
Default Re: Valve Cover Gasket (Eluzion)
Use a torque wrench!
I thought I could get away without one last time I popped off my valve cover and I broke one of the bolts! Fortunately I was able to get the broken piece out of the head, otherwise I would have been pretty screwed ... $1.99 + shipping for the replacement bolt for me!
-a
Old Oct 29, 2002 | 11:45 AM
CivicEx95's Avatar
Where do you apply the honda bond at? Do you need to place it on the o rings around the spark plugs?
Old Oct 29, 2002 | 03:58 PM
ULTRA911's Avatar
Default Re: Valve Cover Gasket (CivicEx95)
just apply it where it makes contact with the valve cover & head. you dont' really need a torque wrench.
Old Oct 29, 2002 | 04:43 PM
b19coupe's Avatar
Default Re: Valve Cover Gasket (ULTRA911)
Hondabond on the 8 corners of the gasket, a little goes a long way.
Old Oct 29, 2002 | 05:16 PM
Eluzion's Avatar
Ahh so I do or don't need a torque wrench? Haha
I figured I'd just use my hand till their snug and give it a full turn (or less depending on how tight it feels).
Old Oct 29, 2002 | 06:42 PM
You don't need a torque wrench for something small like that. Now if you have ape hands and you are not good at having a good feeling of how close you are to stripping a nut or bolt, then you need one.
Old Oct 29, 2002 | 06:44 PM
3rdGteg's Avatar
I don't think replacing the valve cover gasket everytime you pull the cover off is necessary, but if u can afford it, go for it! I've pulled the cover off mines like 10 times already and the same gasket works fine.
Midori Green
Jun 1, 2007 10:53 AM
RaceMyGhost
Jul 7, 2006 11:03 AM
Silver_lude
Mar 22, 2006 02:20 PM
KOALA YUMMIES
Oct 29, 2002 01:56 PM
FSTRex
Oct 5, 2001 09:07 AM
