CRX shuddering/jerking
Old Feb 23, 2014 | 12:48 PM
DamnThatsRexy's Avatar
Default CRX shuddering/jerking
I'm having a problem with my 90 CRX hf, sometimes when im driving it'll just shudder(i guess is the word to describe it). It doesnt seem to be doing anything yet, but a few months ago i had this same problem so bad to where i couldnt even drive the car, and at stop signs and things it'd just turn off. Because of that incident, i replaced ICM, cleaned out the EGR, new PCV and hose, and changed the main relay. What else could be causing this?? SHould i take it to my local advance or what do you guys think?
Old Feb 23, 2014 | 02:00 PM
instrument's Avatar
Default Re: CRX shuddering/jerking
furl pump/ filter as well and a tune up if its been a while.
Old Feb 23, 2014 | 02:25 PM
sorry, forgot to finish that list for some reason. Also have gotten new spark wires, new dis cap and rotor and filter. Havent changed the fuel pump though
Old Feb 25, 2014 | 01:52 AM
Natemugstah's Avatar
Try some sea foam and give the inside of you engine a clean . Could be dirty injectors . If so its a easy fix . Hope its not the fuel pump .
Old Feb 25, 2014 | 11:35 AM
ghosthatch's Avatar
motor mounts can give you a mean jerking too
DAtegLs
12
Jan 31, 2010 07:20 AM
bindolus
Sep 17, 2009 06:09 PM
riyakhan
Sep 1, 2007 05:08 AM
cfwthb_94
10
Dec 18, 2006 07:35 PM
CoolRedXylophone
Feb 17, 2006 08:22 AM
