Zeal/Mugen/BuddyClub/etc.. suspension share your experience
Old Oct 29, 2002 | 07:08 AM
austrian type-R's Avatar
Default Zeal/Mugen/BuddyClub/etc.. suspension share your experience
I want to upgrade my suspension and my tuner wants an all out autoX car. What are the pro and cons on those and other brands, which one wuold you drive, which one would you buy again.
Old Oct 29, 2002 | 07:11 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (austrian type-R)
I run race valved JIC's on my Honda Challenge car. All of these systems are going to be similar. Make sure you spec your own spring rates unless you don't mind mild understeer.
Warren
Old Oct 29, 2002 | 09:12 AM
jonnybravo's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (Warren)
Warren
What spring rates do you run and how neutral is your steering. What model JIC's do you run and are JIC's the same as Zeal?
Old Oct 29, 2002 | 09:39 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (jonnybravo)
It's pretty damn loose. Neutral on throttle though. The model is a modified FLT-A2. Spring rates are high. This is a race car we're talking about. I'm running about what a World Challenge, or any fast Honda would run. Lots of spring up front, and more in back, with a big rear bar.
Warren
Old Oct 29, 2002 | 10:16 AM
AJ PwR's Avatar
Spoon Pretty much the best for your DC2. Showa were used in N1 , Gr.A race series as well as stock dampers. Spoon's are well developed for street, Auto-x and track usuage. Extremely durable. One of my favorite .
Buddyclub Racing Spec - has a bigger tunability ranges over ZEAL cuz of piston size. It can be softer and stiffer over ZEAL B6/S6. Bad thing is they are quite heavier cuz of the chromoly steel and aluminum components. Pillowball upper mounts comes as standard so you will benefit more turn in response.
Buddyclub P.1 dampers- Full aluminum construction. Super lightweight.HUGE tunability ranges from soft to stiff. Top notch quality and performance but bling* bling*
ZEAL- B6/S6 same internals . Very streetable , nice ride and not bumpy at all. Since they don't come with pillowball uppermounts , turn in is not as sharp.
B2s , best bang for the buck.
Mugen-low down no comments .N1 dampers are AWESOME you don't need to ask but race damper is made for racing , just make sure you note that.
Here my little rating for them.
1) Buddyclub P.1 dampers (custom spec)
2) Mugen N1 (race use only)
3) Spoon N1 (street to track)
4) Buddyclub Racing Spec (street to track)
5) ZEAL B6/S6 (high quality street damper)
6) ZEAL B2 (best bang for street)
Old Oct 30, 2002 | 04:30 PM
gandhisan's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (AJ PwR)
Where does Super Functions fit into your list, or are they not on your list?
Old Oct 30, 2002 | 05:48 PM
mantic6t9's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (gandhisan)
Does SSR offer custom spring rates for their coilovers that can be bought seperatly?
Old Oct 30, 2002 | 07:15 PM
AJ PwR's Avatar
I totally forgot I will rate it in under Spoon.
Old Oct 30, 2002 | 07:32 PM
RagingAngel's Avatar
My vote goes to Showa too...despite the fact I had to sell mine..... DOh...
But that's only cuz Ben promised to sell me a new set for 1dollaH!! Uh..thas after I would already give him 3299 dollahs .....
Old Oct 30, 2002 | 08:30 PM
mantic6t9's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (RagingAngel)
What do you guys know about these? I don't know much about them.
Old Oct 30, 2002 | 08:33 PM
AJ PwR's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (mantic6t9)
No objections to SRR but the thing is rarely ppl run them. For that kind of price , I would rather go for something with a brand name you trust.
Old Oct 30, 2002 | 08:51 PM
mantic6t9's Avatar
The guy wants 800 for them 700lbs front 400lbs rear.
Old Oct 30, 2002 | 09:06 PM
YTYPER's Avatar
SRR are good stuff, I used it on my TYPE R too. I loved it more than TEIN.
At first I used TEIN NA with H&R sport spring, after half year a change to HA with 12K front and 8K for the rear. On the track still not good enough for me. Also TEIN coilover is not big valve and short body. Then I choose SRR, although SRR cost pretty much, I still choose it. Because it is aluminium body, short body big valve and can use high spring rate( I used 20K and 18K) I used it on the track is much more better than TEIN. Although that price I can get TEIN RA, but TEIN RA can only afford to 16K, also you have to use the travel of the shock to adjust the height. I like SRR ride and on the track too.
Old Oct 30, 2002 | 09:07 PM
uNF$@#!'s Avatar
wow, with that set up your handling will hardly be neutral...oversteer central
Old Oct 30, 2002 | 09:11 PM
mantic6t9's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (Soup ****)
Yes i know these were setup for drag racing. This is why i was wondering if they offer other rates that i can buy.
Old Oct 30, 2002 | 10:35 PM
AJ PwR's Avatar
Depends on camber setting too.
Old Oct 31, 2002 | 12:45 AM
Maximus's Avatar
Ben, have you ever had any experience with JIC Magic coilovers? I have heard mixed reviews about them.
Old Oct 31, 2002 | 04:11 AM
xtrafastcivic's Avatar
wouldn't it be more oversteer if it was stiffer in the back??? and for drag it would be stiffer in the back too.......
Old Oct 31, 2002 | 04:14 AM
Back in Black's Avatar
Rather OG
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (XtraFastCRX)
Yes. However a lot of other factors go into how much oversteer/understeer you'll have with a certain setup. Tire pressures, sway bars, driving style, etc can all have a significant impact.
Old Oct 31, 2002 | 08:13 AM
Smitdog's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (Jason Franza)
I am so happy with my Buddy Club Race Spec Dampeners. The exact tunability that I am looking for for Auto X's and Track Events. I dont mind the tad extra weight that comes with these coilovers.
Old Oct 31, 2002 | 09:25 AM
AJ PwR's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (Maximus)
JIC ? I used to have a lot of friends selling and ran them in HK. I've seen them in person and it doesn't look impressive but most of the review for ppl who bought them in HK said thay are crap. Pillowball uppermounts were making sound and the seal doesn't last and they fail very easily right from the very beginning. This info were from few years ago but anyhow I assume JIC must improve their products in the 2002.
Old Oct 31, 2002 | 09:45 AM
SpoonEK2's Avatar
Hey Aj,
Where would TEIN Type FLEX fit on your list if it was on there? Are they comparable to the Zeal B6?
Old Oct 31, 2002 | 10:40 AM
Petah's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (SpoonEK2)
What about the TEIN RAs? how will they fair against the others?
Old Oct 31, 2002 | 11:17 AM
Hooch'n's Avatar
Default Re: Zeal/Mugen/BuddyClub/etc.. suspension share your experience (eg-six)
.....good info. THinkin Buddy Club yo!
Old Oct 31, 2002 | 11:36 AM
spoon_ek9's Avatar
i got my jic flt-a2 for about 1.5 year, drive the car everyday, 10+ track events, so far so good, i like them.
