4th Gen rear brakes
Old Feb 22, 2014 | 03:01 PM
1986Cbracing's Avatar
Default 4th Gen rear brakes
1993 prelude Si
I've done the vTec front brake conversion. My question is are the rear brakes for the vTec larger as well? I'm guessing if they are it is the same swap as the front as far as brackets and so forth but for the rear calipers.
Old Feb 24, 2014 | 05:09 PM
Default Re: 4th Gen rear brakes
Anyone?
Old Feb 24, 2014 | 05:50 PM
holmesnmanny's Avatar
compare the part numbers at hondapartscheap.com
Old Feb 26, 2014 | 01:37 PM
According to that site there is no difference. I was just surprised that the front vTec brakes are so much larger than the rears. I have checked websites before and they told me there was no brake difference between the vTec and Si on the front brakes, althought everyone knows this isnt true, so I figured someone here would know for sure.
Old Feb 26, 2014 | 06:40 PM
integra_101's Avatar
They are not different. The type s, SH, SR, SI, SRV all share the same rear calipers.
Old Feb 27, 2014 | 12:45 PM
tclmember's Avatar
All the same rear calipers.
Old Feb 27, 2014 | 01:35 PM
Good deal, thank you. I did the vTec front swap and didn't know if there was a swap for the rear or not. Thanks
Old Mar 3, 2014 | 03:16 PM
Sparksman's Avatar
Im pretty sure all 4th gens came with drums in the rear other then the vtec models. So all rears should be the same on 4th gens if disk, aka vtec model ones.
The 4th gen fronts are different, the Vtec model has over sized rotors. So there is a difference between the Vtec model's and the SI's, and that is the size of rotor they are to be used with. The smallest rim you can fit on Vtec calipers is 15"s, but you can get 14"s on the smaller SI's calipers.
The fronts are the same as 5th gens, im 100% sure about that.
As for the rear of 5th gens, my guess they would be the same as 4th gens.
Old Mar 7, 2014 | 09:30 PM
yohan's Avatar
rears are disc brakes on all 4gen. not drums
93h22a1vtec
Jan 25, 2006 09:18 PM
93h22a1vtec
Jan 25, 2006 04:27 PM
es_squared
May 19, 2004 08:45 AM
prelittlelude
Aug 5, 2003 02:43 PM
TypeSH
Feb 5, 2003 08:38 PM
