Radiator fan not coming on
I have jumped the ECT and fan did not come on. I hard wired the fan to the battery and the fan came on. I have checked all fuses and they are all fine. I even switched out the relay and still nothing. Any help at this time will be appreciated.
if you jumped the ect sensor thats under the distributor,you jumped the wrong one... the fan switch plug is in the thermostat housing on 92-00 civic and 94-01 integras..this is the plug you need to jump for the fan..if fan comes on then the switch is bad,if it doesnt come on when jumped then theres is another problem....remember the key needs to be in the on position...
thisdamnhonda
21
Feb 26, 2012 09:47 AM
Whatever
Apr 23, 2009 09:49 AM
Doh!
Jul 3, 2006 09:29 PM
