Transmission & Drivetrain Gearboxes, Differentials, Clutches
Play in steering wheel
Old Feb 22, 2014 | 11:32 AM
jonyi27's Avatar
Default Play in steering wheel
I'm changing my rotors and pads and turning my wheels side to side I have play and wheel is locked, tie rods don't look like there moving, can this be my rack??
Old Feb 22, 2014 | 12:34 PM
First.EG's Avatar
Default Re: Play in steering wheel
Even if your wheel is locked you'll still have a bit of play. At least I do cause when I was checking mine I could see my steering wheel moving.
Old Feb 22, 2014 | 01:47 PM
mike_1212's Avatar
Are both front wheels off the ground? Make sure 1 (not the one you are shaking) is on the ground and try again. if you still have play it could be a bad bearing, inner/outer tie rods or rack. Look for where the play is coming from while your shaking the wheel.
Papalou
Jan 19, 2014 10:40 AM
lildragon'07
13
Jun 2, 2010 08:31 AM
HeikDiesel
Suspension & Brakes
Sep 4, 2008 12:38 AM
A Blue Lude
May 25, 2006 11:10 AM
