Help me diagnose my creaky, squeaky, sounding ITR
Old Oct 29, 2002 | 06:50 AM
Snapspinnr's Avatar
New User
Default Help me diagnose my creaky, squeaky, sounding ITR
OK here is the symtoms. I have an almost rubbing, grinding sound at low speed that is speed dependant. As in it goes rub, quiet, rub, quiet, rub. The slower I go the slower the frequency of the noise. At higher speeds the noise either disappears or is a softer higher pitched squeak.
The position of the left front suspension seems influence the noise. It is louder when braking or turning right. The noise is usually gone when you are accelerating or turning left.
I'm thinking that it is a CV joint type problem but I'm not the most knowledgable mechcanic out there.
Thanks in advance for the help
Old Oct 29, 2002 | 07:43 AM
coquinn's Avatar
Default Brake Dust Shield
Sounds like your brake dust shield is rubbing.
Old Oct 29, 2002 | 08:10 AM
Snapspinnr's Avatar
New User
Default Re: Brake Dust Shield (coquinn)
That would be too easy I'll take a look at it.
Old Oct 29, 2002 | 12:18 PM
Snapspinnr's Avatar
New User
Default Re: Brake Dust Shield (DOHC_VTEC)
Yep, I have a Yella arrr. Why? Do you know Fuquay?
Old Oct 29, 2002 | 06:20 PM
#417R's Avatar
Default Re: Help me diagnose my creaky, squeaky, sounding ITR (Snapspinnr)
I would check the hub bearing out also.
Old Oct 29, 2002 | 06:28 PM
uNF$@#!'s Avatar
Default Re: Help me diagnose my creaky, squeaky, sounding ITR (Y2KITR)
rotor?
Old Oct 29, 2002 | 09:15 PM
Paste's Avatar
Loved
Default Re: Help me diagnose my creaky, squeaky, sounding ITR (Soup ****)
grease your bushings
Old Oct 30, 2002 | 09:37 AM
Cheeseman's Avatar
sounds like a borderline wheel bearing or slightly warped rotor to me.
Cheese~
[Modified by Cheeseman, 10:38 AM 10/30/2002]
Old Oct 30, 2002 | 10:41 AM
Tweakmeister's Avatar
Default Re: Help me diagnose my creaky, squeaky, sounding ITR (Cheeseman)
brakes
d_hun23
Honda CR-V & Element
Oct 1, 2015 06:53 AM
k20eklipse
Aug 3, 2010 08:40 PM
BxEF
10
Sep 11, 2008 05:51 AM
_RedRiceR_
Jun 19, 2006 12:59 AM
MyLittleRedCar
Oct 20, 2003 10:48 PM
