93 Civic - no spark and fuel pump won't prime
Old Feb 21, 2014 | 11:31 PM
gsr_b20b's Avatar
Default 93 Civic - no spark and fuel pump won't prime
Hey so my girlfriends car is having a no start issue. Its a 93 hatchback dx automatic. She was driving and pulled over for a minute and as soon as she put the car back into drive it died. The past 2 weeks we've had issues with the fuel pump relay, when the same thing would happen. So I assumed it was just that. I replaced the fuel pump relay but that's not the issue. If i turn the key to the on position (when the fuel pump should prime) but its not priming. So I checked with a test light to see if there's power at the fuel pump relay and there is power on 2 wires of it which I assume is normal. With the test light I found that there is no power at the fuel pump if the key is turned on and there's no power being sent to the fuel pump when the motor is turning over. The main relay clicks like it should and I also have tried a different main relay with no luck. I've tried pulling codes but the check engine light just constantly stays on and doesn't flash to reveal a code (with the little blue ecu plug being jumped). I've checked the ecu fuse but its fine. Then me and a friend decided to run a hot wire straight from the battery to the fuel pump. And run a ground to the body of the car off the fuel pump. With this the fuel pump turns on and seems to be working. I try turn over the car but it won't start. Im really stumped here, could it be a bad ecu? Or some sort of other fuse/relay? Please help!
Old Feb 22, 2014 | 07:54 AM
Former User's Avatar
Default Re: weird no start issue. please help
When the engine won't start, does the starter still crank the engine fine? If so, have you tried cleaning and tightening the G101 ground attached to the thermostat housing?
Old Feb 22, 2014 | 09:40 AM
gsr_b20b's Avatar
Default Re: 93 Civic - fuel pump won't prime
yes the starter still cranks the motor fine. ill check that ground, could it be something so minor?
Old Feb 22, 2014 | 10:04 AM
Yep
Old Feb 22, 2014 | 09:35 PM
gsr_b20b's Avatar
Cleaned all engine grounds including the thermostat ground and still no power to the fuel pump.
Old Feb 22, 2014 | 09:45 PM
Check whether 15A dash fuse 24 is blown.
Old Feb 22, 2014 | 10:15 PM
gsr_b20b's Avatar
I checked, its good
Old Feb 22, 2014 | 10:18 PM
gsr_b20b's Avatar
im getting so confused, different pgmfi relay, different fuel pump relay, just tried a different ecu, cleaned all fuses in the engine compartment, including the thermostat ground. checked all the main connections on the tops of the strut towers in the motor bay and still no power to the fuel pump
gsr_b20b's Avatar
didn't clean fuses I meant to say cleaned all grounds
Old Feb 23, 2014 | 05:23 AM
Is there spark at the plugs?
Old Feb 23, 2014 | 07:55 AM
gsr_b20b's Avatar
ill test that in a bit and let you know
Old Feb 23, 2014 | 07:58 AM
gsr_b20b's Avatar
would a 5spd ecu actually work in a automatic civic? cuz I tried the 5spd p30 ecu out of my ef in my girlfriends car lastnight. And still had no power at the fuel pump
Old Feb 23, 2014 | 04:28 PM
gsr_b20b's Avatar
Car is also getting no spark. Replaced distributor and still no spark. But there is power going to the distributor. Could something be disabling the distributor and fuel pump?
Old Feb 23, 2014 | 09:31 PM
  1. Unplug ECU connector A.
  2. Turn key to ON(II).
  3. Ground pin A7 or A8 in the unplugged ECU connector to the metal frame under the dash.
  4. Does the fuel pump run?
Old Feb 24, 2014 | 10:49 AM
gsr_b20b's Avatar
Okay ill try that. You mean ground the ecu or ground the "a" plug on the harness?
Old Feb 24, 2014 | 10:57 AM
The A7 or A8 connector pin, not the ECU.
Old Feb 25, 2014 | 04:16 PM
gsr_b20b's Avatar
Default Re: 93 Civic - no spark and fuel pump won't prime
Just tried grounding those 2 wires and no fuel pump power still
Old Feb 25, 2014 | 04:21 PM
gsr_b20b's Avatar
Even ran a test light off the fuel pump plug to test as well
Old Feb 25, 2014 | 04:24 PM
Was the key in ON(II)?
Old Feb 25, 2014 | 04:31 PM
gsr_b20b's Avatar
Yes it was
Old Feb 25, 2014 | 04:36 PM
Yes it was
Your test result tells you that the problem lies in the main relay circuit rather than being a bad ECU.
Do you have a multimeter?
Old Feb 25, 2014 | 04:39 PM
gsr_b20b's Avatar
Oh okay that makes sense. I can borrow one from a friend
Old Feb 25, 2014 | 04:45 PM
Post again when you have a multimeter and also post a picture of it if you don't know how to use it.
Old Feb 25, 2014 | 04:49 PM
gsr_b20b's Avatar
Okay I will do. Thank you for the help so far
Old Feb 25, 2014 | 10:47 PM
gsr_b20b's Avatar
this is the multimeter
