Millenia Wheels meet Spoon Calipers
They do not fit with out spacers.... I tried moving the washer and off seting the caliper, then grinding the calipers down some, but it still would not fit. 5mm spacer is close, 6mm spacer works perfect.
Here you can see where i hit them with the die grinder (circled in red)
Here is where they still hit inside the rim
so, you mean OEM rims like my Enkei 6x15 offset 50mm will clear the Spoons?
Each wheel is different.
But I've never heard of people using the Spoon calipers for the 15" wheels that come stock on the Euro/Aussie ITRs. You better find out before making the purchase.
Actually spacer is not a bad thing at all. It helps the car tracks in better, quite noticeable too.
hell i would grind spoon calipers ....who cares what they look like..as long as they brake...i would end up painting them black anyways ....who wants smurf blue calipers ...not me
Damn straight... I had the car cleaned once at the dealer (they did it with out asking me
) anywho, they pressured cleaned the calipers and the blue came back out... all the stunnas were jocking them... i hated it... took them off the next day and painted them again... BBQ paint ownz da spoons
OT, but do the newer chr0med 5-spoked Millenia wheels fit Rs too? Anyone know the weight of those?
Edit: This is the wheel I was talking about, but found out it is a 17". No thanks.
[Modified by BrewCityR, 4:41 AM 10/30/2002]
*cringing*
you are crazy for doing that to calipers that cost a grip... let me know where you got your money tree hehehe
grinding the caliper down??!!
*cringing*
*cringing*
*cringing*
who cares what they look like ...function over fashion ....only stunnas worry about looks
ITS NICE HAVING A NICE LOOKING CAR. NOTHING WRONG WITH THAT. JUST CAUSE YOU TRACK YOUR CAR DOESN'T MEAN YOU HAVE TO LEAVE IT DIRTY.
*cringing*
*cringing*
*cringing*
I would have ground the spoon and nisson logos off first. Then ground a bit more off then he did, I bet we could make em fit
plus we are talking about brake calipers here, not a car.
IMO smurf blue calipers don't make a car look good
Craig, just make sure you stop grinding when you see brake fluid coming out.
