Speed Cable Honda CRX "B" Series
Old Feb 21, 2014 | 01:01 PM
uptoup's Avatar
Icon2 Speed Cable Honda CRX "B" Series
as I can connect the speed honda CRX B series, or should I change the meter?
Old Feb 21, 2014 | 01:57 PM
bairdandrew77's Avatar
Default Re: Speed Cable Honda CRX "B" Series
huh?
Old Feb 21, 2014 | 02:06 PM
Charlie Moua's Avatar
he's in honduras........ probably just language issue
Old Feb 21, 2014 | 02:17 PM
Freemananana's Avatar
Agreed. Your meter should be fine if the cable goes in the transmission.
Old Feb 21, 2014 | 03:53 PM
Deetz's Avatar
Crazy Honda Guy
depends on two things...
the cluster? manual or electric?
the speed sensor on the tranny, which can be switched out
Old Apr 18, 2014 | 08:50 AM
uptoup's Avatar
I have a CRX B18C engine, the speed sensor is not the same as acura integra
Old Apr 18, 2014 | 11:47 AM
welfarepc's Avatar
In our cars, the VSS pulser is in the gauge cluster.
You have the option to either put a cable into your transmission, or to run the VSS pulse from the pulse generator on the transmission to your ECU, and have no speedometer on the gauge cluster then.
Old May 7, 2014 | 07:44 PM
uptoup's Avatar
thks!
Khrystin
Sep 15, 2018 12:25 PM
jdm_h22
May 4, 2013 02:53 PM
cmkwood
Mar 24, 2013 10:49 AM
PayMecracka
Apr 10, 2011 07:59 AM
crawfo661
12
Oct 22, 2009 04:04 PM
