Power Steering Suggestions
Sup HT,
I'm in the process of searching for reliable, replacement power steering pump for my 97 Accord SE. As far as quality, what brand will I find the most reliable? Thanks
OEM rebuild from auto store?
I don't think anyone really makes an aftermarket power steering pump and all of the ones from auto stores are going to be a crapshoot.
That's going to be fairly expensive. Alternators are more of a crap shoot than power steering pumps. I would just go the aftermarket and they are going to be limited lifetime warranty too which is great, but if it's going to be bad it will be bad as soon as you start it up and they aren't hard to remove anyhow.
Just got one from Advance Auto tonight for $70 + the core charge.
When replacing the pump, do you guys recommend getting a new pulley and belt?
Anyone have a DIY on how to replace the pump? Not sure if there is anything special about doing so. (bleeding, removing pulley, how to know how much tension there should be).
Forgot to update this!
Got it replaced along with the belt. My only issue was realizing that the bolt on the pulley was threaded the opposite of normal. Oops.... Aw well, ended up needing to replace the pulley since I messed the old one up but its all good now! Just need to tighten up the belt a tiny bit and it will be perfect.
