205-50-16 tires
Old Feb 20, 2014 | 06:03 PM
duf2570's Avatar
Default 205-50-16 tires
im in the choice of 16 inch tires on jdm itr wheel right now im on very used 205-50-16 tire(dont remember the brand) and no rub problem,,i love the look but i want to know if someone have run those size on 16 inch oem jdm or aftermarket wheel( new tire of curse) ,,yes i will be off on my speedo,,,but my R a weekend car so its not a issue for me
or i should really go with 205-45-16
Old Feb 20, 2014 | 06:07 PM
white rocket's Avatar
Default Re: 205-50-16 tires
205-45-16 or 215-45-16 are ideal
Old Feb 20, 2014 | 06:30 PM
duf2570's Avatar
This is what ive read a lot on the web .... I was looking for 215/45/16 but here the cheapest tire is khumo at 170$ eah im not a low budget man but close to 800$ for 4 tires my god...
Old Feb 20, 2014 | 09:03 PM
The 205 width is more common so prices should be cheaper. I run that size and it's fine for daily use on average to shitty roads even with suspension modifications.
Old Feb 21, 2014 | 02:45 AM
duf2570's Avatar
What about the look.. so i hate ricer look(thin tires) and want to do the best choice
Old Feb 21, 2014 | 03:06 AM
Acura98guy's Avatar
As Soft As A Rock
45 series sidewall is fine.. I've had 40, 45, and 50. 45 rides nice, but man is 40 a PITA.
It doesn't look thin, but doesn't look like the michelin man around your rim either.
Old Feb 21, 2014 | 08:44 AM
Todd00's Avatar
I said I don't want a title!
Depends upon the tire and what you do with the car.
Personally, I like the 215/45/16, but tire choice is limited. 205/45/16 has much more available in terms of hi-po tires (and tires in general)
Old Feb 21, 2014 | 11:54 AM
duf2570's Avatar
I dont do track or drag. My R is a weekend car.. weird but i like the fact that on 205/50/16 my rpm will be lower at 60mph due to the bigger tires...like ive write.. im actualy on those tires size but they are used and they are (i guess) similar size to the 205/45/16
Old Feb 21, 2014 | 12:08 PM
Todd00's Avatar
Diameter:
205/50/16 = 24.1"
215/45/16 = 23.6
205/45/16 = 23.3"
stock 195/55/15: 23.4"
Old Feb 21, 2014 | 12:46 PM
duf2570's Avatar
Diameter:
205/50/16 = 24.1"
215/45/16 = 23.6
205/45/16 = 23.3"
Humm i didnt see it like this... In mm(596vs591) its its look like more "different" vs inch mesurement(1/4)...good point thanks
Edit:if anybody can show me 205/45/16 tire on jdm wheel
Old Feb 21, 2014 | 01:07 PM
Seedc2's Avatar
wow didn't realize diameter for the 205/45/16 was nearly identical to stock
Old Feb 21, 2014 | 07:11 PM
dimo92's Avatar
205 50 16 over here. michelin tires. rides great, love it it compared to 40s
Old Feb 21, 2014 | 07:21 PM
duf2570's Avatar
Look good
Old Feb 22, 2014 | 09:17 PM
KraZyCHOWMEIN's Avatar
Side track I just bought a set of 16" wheels it came with 225/50/16 +35 offset. The tires bulge so much I'm looking for replacements tires. With this offset what would you guys recommend?
Thanks.
Old Feb 23, 2014 | 09:25 PM
Todd00's Avatar
There is no need to kill the gear ratio even more with a taller tire, especially when the 205/45 and 215/45 are so close to stock and offer plenty of tire choices.
It will also keep your speedo accurate.
Old Mar 2, 2014 | 06:24 PM
duf2570's Avatar
finally ive got a good 215-45-16 bridgestone playZ tires,,for 300$
decko
Nov 9, 2010 06:17 AM
Probot
Apr 2, 2007 09:01 AM
I_LOVE_HONDAS
Jul 16, 2006 08:24 PM
DarkTeg94
Mar 7, 2006 07:59 AM
gavhowe
Sep 27, 2002 08:23 AM
