help car wont start and limp mode
Old Feb 18, 2014 | 03:26 PM
crookson speed's Avatar
Default help car wont start and limp mode
i was driving down the street the other day and my car went into limp mode and it was bogging on the way up there. then i saw some loose solder connections to my ecu so i fixed that then the light dosnt even turn on in the ecu and the fuel pump dosnt prime. when the car did run it started up fine was still in limp mode but when i shut it off i had to wait so it could start again. btw its a 1990 honda civic si with a pr3 obd0 ecu with a jdm b16.
Old Feb 18, 2014 | 05:24 PM
instrument's Avatar
Default Re: help car wont start and limp mode
no light means no ecu, so check your wiring and check your thermostat groundx and check the ecu.
sounds like you had some solder points with no shrinkwrap, may have blown up your ecu, may just be crossed wires.
Old Feb 19, 2014 | 09:55 AM
ive read that when the ecu is dead the led stays lit. how do i know for sure my ecu is fryed. thanks
Old Feb 19, 2014 | 01:32 PM
instrument's Avatar
light shouod come on when you start car, if it doesnt couod just be a bad light. you test it in another car or put another ecu in your car.
KDvtec5757
Jul 18, 2009 06:33 PM
Darren
Jul 18, 2005 05:12 PM
lude97dude
Jan 26, 2003 10:14 AM
