my first swap need help
Old Feb 18, 2014 | 02:20 PM
Turquoistorpedo's Avatar
Default my first swap need help
So i blew my d16a6 in my 91 si crx and resently bought a d16z6 out of a 93 ex to swap into it and need help from someone that has done this swap before to figure out what i need for it to work properly and any tips to make the swap easy and not a headake
Old Feb 18, 2014 | 04:10 PM
SIRX's Avatar
Default Re: my first swap need help
for the love of god please do a search maybe 10 years ago this would have been a big issue (nope not even then) it has been covered way to many times. Welcome to HT
Old Feb 18, 2014 | 04:17 PM
SuperSasQuatch's Avatar
http://www.ef-honda.com/ben/EFswapguide.html
Old Feb 18, 2014 | 05:02 PM
i know it bolts rite up and i can use all the axles and tranny and mounts from my stock si. i guess the real question its the wiring harness and ecu hook up.
Old Feb 18, 2014 | 05:22 PM
Glowicki's Avatar
Are you going to go obd1 or stay using obd0?
If obd1, I think you'll need to use a p28 ecu with an obd0 to obd1 jumper harness. You'll also have to follow a write up on how to convert your car to obd1.
The link in a previous comment will help you tremendously.
Old Feb 18, 2014 | 05:33 PM
instrument's Avatar
to make it easy use your stock harness with you crx injectors, getta p28 ecu(make sure its a manual) and a obd1 conversion harness. youll have to wire the d16z6 distributor to work or buy a conversion harness. youll also have to wire a four wire 02 sensor and wire your vtec from the conv harness.
there are a bunch of walk throughs around that go into deeper detail.
Old Feb 19, 2014 | 03:02 AM
Freemananana's Avatar
FAQs at the top of this sub forum actually have a walkthrough still. I also posted a OBD0 to OBD1 conversion that detailed the wiring of VTEC, O2, ect.
Old Feb 21, 2014 | 07:27 PM
Old Feb 21, 2014 | 07:41 PM
i got the p28 ecu but is there a conversion i have to to to make it fit with obd 0, and the stock d16z6 distributor came with the motor. My harness is a Iffy obd1 harness im going to have to do some back yard s**t to it and fix the bi**h, its for the motor i bought but IDK about it. the o2 sensor is something i thought about, but i wasnt sure about thnx.
Old Feb 21, 2014 | 07:42 PM
please get into detail when you get time i could use any help
Old Feb 22, 2014 | 01:44 AM
Spug's Avatar
They're pretty much the same engine. Put it in the same way you take/took the blown one out.....
Old Feb 22, 2014 | 06:38 AM
Go to the top of the page, click FAQ, click D16Z6 SWAP. Done. There is a flippin write up.
Old Feb 22, 2014 | 09:18 AM
instrument's Avatar
from the guy that called me rude, niiiice.
op, if after reading the faq you have any specific questions i'll gladly try to help, it is fairly straightforward
Banner
Jun 15, 2010 08:09 AM
juandaman
Mar 26, 2009 02:43 AM
ERKK
23
Mar 9, 2009 04:25 PM
cjwarren4dcivic
Feb 3, 2006 01:17 PM
CivicManLs
Mar 2, 2005 09:53 AM
