Honda CR-V & Element 2WD & 4WD Element & CR-V
Power Steering Pressure Hose replacement
Old Feb 18, 2014 | 09:00 AM
luisfer66's Avatar
Default Power Steering Pressure Hose replacement
Hello all!
My mechanic has told me that the power steering pressure host needs to be replaced. The part alone was quoted @ over $300. I have searched the part online and found the OEM part for a little less but not much. I did, however, find the part for under $100 but it's not OEM. The brand is Gates.
Would you recommend getting the OEM part or the Gates brand part?
Thanks!
Old Feb 18, 2014 | 02:55 PM
78F350's Avatar
Default Re: Power Steering Pressure Hose replacement
Gates makes good quality belts and hoses. Some Honda OEM parts *are* Gates.
Old Feb 19, 2014 | 10:29 AM
kapoosh valve's Avatar
I had to replace mine recently and went with Edelmann. $59 shipped on ebay.
Old Feb 19, 2014 | 11:55 AM
dogbiscuit's Avatar
I've replaced everything except that hose on mine including the pump. the worse was the return lines down on the subframe I couldn't find anything but OEM
Old Feb 19, 2014 | 08:36 PM
Shingleback's Avatar
I would use Gates products; I have had good experience with them in the past.
Dekorum
Aug 6, 2018 01:24 PM
Kennethbtaden
May 14, 2017 03:05 PM
redm3turbo
31
Dec 25, 2013 06:52 PM
redsidriver
Aug 28, 2008 01:30 PM
Dwight Schrute
Apr 26, 2006 07:53 AM
