Suspension & Brakes Theory, alignment, spring rates....
? about ASR SFB
Old Feb 17, 2014 | 09:24 PM
Socal Vtec's Avatar
Default ? about ASR SFB
Is the there any other sway bars that will fit on the asr subframe brace on an eg civic. i dont want to run a 24mm i think thats to big even for track purpose only. does any one have any opinions or setups they have or think i should run. I as well need a front sway bar what would be good for track use only i was thinking 24mm up front and 22 or so in back.?? please help!!
Old Feb 18, 2014 | 03:29 AM
rvn2svn's Avatar
Default Re: ? about ASR SFB
An OEM ITR 22 mm will work. I'd recommend a stock front bar off an integra and an ITR rear to start. Swaybars are a "personal preference" sort of thing. Some people like their cars a bit more loose ( bigger rear sway) than others. The type R rear is a great start because its a big improvement over stock, cheap and shouldn't be overwhelming the first few times you drive with it. If you like it, great! If you feel like you need more, then get a 24+.
Integra model - Front / Rear diameter (mm)
86-89 All Models - 17.0 / 17.0
90-93 All Coupes - 23.0 / 14.7
90-93 All Sedans - 23.0 / 15.9
94-99 RS/LS/GS/SE Coupe - 22.1 / 12.9
94-99 RS/LS/GS/SE Sedan - 22.1 / 14.0
94-01 GS-R - 24.0 / 14.0
97-01 Type R - 24.0 / 22.0
98-01 LS/GS Coupe - 24.0 / 12.9
98-01 LS/GS Sedan - 24.0 / 14.0
Old Feb 18, 2014 | 05:49 AM
GagnarTheUnruly's Avatar
I think the ITR rear sway is a perfect size also. It makes the car more willing to turn without being overly twitchy. PM me if you are interested in buying a GSR front sway bar.
Old Feb 18, 2014 | 08:26 AM
redlinetuning's Avatar
I'm running a 26mm front (00-si) and 22mm rear (itr) with ASR subframe. The car rotates just fine, some understeer, but with practice it's getting better. I've had some spinouts due to coming in too sharp and braking too late, overturning and causing oversteer.
Old Feb 18, 2014 | 12:24 PM
Socal Vtec's Avatar
do you know where I can get a rear ITR Sway bar??
Old Feb 18, 2014 | 12:52 PM
I bought mine new from Honda. Try oemacuraparts.com or acuraoemparts.com. There are other places too. Prices should be comparable unless the part is discontinued :O
lubmyinteg
Suspension & Brakes
Apr 29, 2007 11:35 PM
JAYBOOGIEZZ
Suspension & Brakes
Apr 12, 2007 01:12 PM
MrTodd
10
May 26, 2005 03:21 AM
MrTodd
10
May 25, 2005 09:46 PM
spock_rocker
May 23, 2004 06:43 AM
