anybody using or have some knowledge about this kind of fuel pump..pls help
Old Oct 29, 2002 | 02:09 AM
_Endless_'s Avatar
Default anybody using or have some knowledge about this kind of fuel pump..pls help
here's a pic of the bosch inline fuel pump i bought used.
i have everything you see in the pic except that brass thing.
the main problem is the fuel outlet which i believe is by the connector side. as you can see, it's not a barb fitting but a threaded one. immediately below the threaded portion are 4 holes around the outlet. i bought a threaded fitting with a barb end today but it only screws in the lenght of the thread and the holes below it are exposed. does anyone have any idea if those holes need to be covered? will fuel come out of it?
i'm going to install the turbo in 3 days and this, i believe, is my only hurdle. i tried searching the web and this board but to no avail. any help will be very appreciated.
[Modified by _Endless_, 11:11 AM 10/29/2002]
Old Oct 29, 2002 | 04:17 AM
RGAZ's Avatar
New User
Default Re: anybody using or have some knowledge about this kind of fuel pump..pls help (_Endless_)
Yes fuel will come out that hole. Change the fitting to a straight-thru model. I think that is designed for a Solex or banjo-type fitting. It should screw out of the pump without any problem.
Randy
maloy
Feb 18, 2015 05:39 AM
94_civicEx
Sep 15, 2004 09:52 AM
1tyme
Dec 23, 2002 11:36 PM
B20-T
Aug 1, 2002 07:49 AM
ludelvr
Apr 27, 2002 09:40 PM
