2009 CRV Tire size
That's over a 5% increase in overall diameter, and is a very unsafe idea if you haven't done necessary upgrades to the brakes and surrounding suspension components to accomodate the new rolling mass.
Would 235/65/17 be safer? I would also like your view under which conditions it will be unsafe. According to Rimsntire webb site the 235/7017 is ok, but recommend to check if it touches anywhere. This I have done and does not touch although very close on the inside when fully turned.
235/65/17 would be within that 3% allotted range.
I have fitted 235/70/17's. Fitted perfectly in wheel arches, does not touch anywhere. Speedometer is showing a reading of 100km/h when GPS shows 100km/h spot on. Fuel consumption will be determined on my way to Namibia and outcome of behaviour on the sand dunes in Namibia.
