P1399 Random Misfire 2000 2.3 Vtec
Old Feb 17, 2014 | 03:57 AM
Tom Mazz/CT's Avatar
Default P1399 Random Misfire 2000 2.3 Vtec
Having trouble with code P1399 - Random misfire. I also get 0301, 0302, 0303, 0304 codes. Have replaced plugs, wires, cap & rotor. Also ran two treatments of injector cleaner. Cleaned up battery ground and ground to body and engine. Removed egv valve and cleaned - everything looks clean.
The car seems to run normal except sometimes at idle it will run a bit rough and CEL will flash....trip the codes. If I give it a little throttle the CEL light will stop flashing.
Car has 165K miles on it.
Tom
Old Sep 30, 2014 | 01:09 PM
madnad's Avatar
Default Re: P1399 Random Misfire 2000 2.3 Vtec
Tom
Wow that is what describes my problem too. I am chasing a p1399 on a 99 Civic HX auto myself. With all four cylinder miss fire.
Have changed out the spark plug, wires, dist cap, rotor, coil and fuel filter. Two treatments of fuel injector (gumout variety) so far. New battery and terminals. Cleaned out the EGR passages (for rough idle issues), caused an air leak but was able to patch it up. Even did a cursory compression test which passed. Injectors are firing fine.
There is a belt squeal when AC is on so my next move will be to replace the idler pulley. There is a mention somewhere that belt tension can cause random missfire. Anyways, hope this will solve my problems. I have gotten upto 32 mpg but now it is down to 24 -26.
I did have to replace 1 Qt oil over two weeks recently but I don't any black smoke or any drips.
It's fun and frustrating trying to get this figured out.
jon9116
Oct 20, 2013 02:17 AM
Mr. Bojangles
Apr 26, 2013 07:47 PM
ftrms
May 1, 2010 11:00 AM
h kid
May 29, 2005 02:32 PM
maxpsi
Sep 10, 2002 12:23 PM
