98 civic ex - can't get to run
Old Feb 17, 2014 | 12:12 AM
eliseosworeze's Avatar
Default 98 civic ex - can't get to run
i have a 98 civic ex d16y8
just rebilt moter....
i have fuel....
bright white spark.....
compretion.....
good wires and plugs normal color tips grayish white...
rolling over feel exast pushing out pressure but wount start
Old Feb 17, 2014 | 12:25 AM
JustHere4ADay's Avatar
WHEEL Slayer
Default Re: cant get to run d16y8
Did you get an exhaust sample? If you did what did you end up getting? That would help us out better.
FYI if you cant find a DYI just grab a sandwich bag, have someone hold it on the exhaust or use a clamp or rubber band. Turn it over and really quick lock the bag and bring it to Autozone or Pepboys. They have the tool there unless you want to spend 500 on it.
you should be right around 200CPSI-350CPSI depending on your readings we can tell you what you need.
Old Feb 17, 2014 | 03:53 AM
Former User's Avatar
Plugs wires in correct firing order?
Injectors spray fuel?
CEL codes?
Hatchmaister98
Jan 25, 2016 05:57 AM
eliseosworeze
Feb 16, 2014 09:07 PM
flymedic37
13
Jun 30, 2013 06:33 PM
Rratedcivichatch
Nov 1, 2002 08:48 AM
