What Speed at What RPM
Was trying to figure out that if my LockUp is working or not. I have 1.8 F18 Engine. At 2k RPM i have 43.5MPH and at 2.8K i have 63 MPH. Do you think its in safe range? some one just said that your car should be at 74.5 MPH at 2.8k RPM. Not sure about that.
I have 91 accord with only Lock Up Solenoid A/B and nothing else on my tranny. Even there is no main and countershaft sensor. its pure hydraulic. Who controls the transmission lockup then? ECU? I believe for just controlling one Solenoid they are not going to put TCU in there
Does your right side cover look like #1
Or does it look like # 1 in this image?
Most members here are from the U.S.A. So our cars/parts/models are different from other parts of the world. A few pictures of the car/drivetrain would help clear up some confusion.
Help us, help you.
As for gear ratios they are different for different engine body and market combinations. You have an F18 so the rpms will most likely be higher compared to a F22 car.
Help us, help you.
navysealsnypre
May 25, 2007 09:12 AM
pkprelude
May 8, 2003 07:58 PM
pkprelude
May 8, 2003 04:48 PM
