Steering wheel off center on 2013 Honda Fit
I have a 2013 Honda Fit base model with 8000 miles. A few weeks ago I was run off a freeway by a truck at about 60 mph into a gravel shoulder. Ever since then the steering wheel is no longer centered when driving straight. It now has shifted to the left. A Honda dealer adjusted the front wheel alignment, which they said was off. They also stated they could not find any damage to the frame or rear wheel axle. But they did say the rear wheels were a little out of Honda specs-there is no adjustment for this on a 2013 Honda Fit. The wheel alignment did not fix the off-centered steering wheel problem. The car does not pull in either direction, nor is there any vibration in the front end.
Any information or suggestions would be greatly appreciated. Thank you very much!
Bent something, maybe tie rod.
If you paid for an alignment your wheel should be straight or they should be able to tell you what is broken causing it to not be straight.
Bring it back
Bring it back
Farquea
May 2, 2018 09:43 PM
Shark Tank
Feb 23, 2003 10:19 PM
