'93 Hatch Rear Defrost Ground Wire location?
Old Feb 16, 2014 | 03:16 PM
69cuda340s's Avatar
Default '93 Hatch Rear Defrost Ground Wire location?
The ground wire on my hatch is not grounded preventing the rear defrost from working. If I run a jumper wire from the driver's side rear glass terminal to negative battery the rear defroster works. Does anyone know where that black rear glass wire, driver's side, is grounded to the body? I have an open circuit I need to trace. Thanks in advance for your suggestions.
Old Feb 16, 2014 | 03:35 PM
Former User's Avatar
Default Re: '93 Hatch Rear Defrost Ground Wire location?
G553 in hatch.
Old Feb 16, 2014 | 05:58 PM
69cuda340s's Avatar
Originally Posted by RonJ@HT
G553 in hatch.
Thanks for reply. Where would that be located...
Old Feb 16, 2014 | 06:03 PM
Also, connector C588 has the defogger ground wire.
Old Feb 16, 2014 | 06:09 PM
69cuda340s's Avatar
Thanks Ron much appreciated....
Old Feb 16, 2014 | 06:12 PM
I added this:
...connector C588 [in the diagram] has the defogger ground wire.
Old Feb 16, 2014 | 06:41 PM
69cuda340s's Avatar
Thanks Ron. If I run a long jumper wire from that C588 connector to the ground terminal at the battery the defroster works. Using an ohm meter its an open circuit between that connector and the battery ground. So for some reason I have an open circuit somewhere back there; that wire is not grounded.
Old Feb 16, 2014 | 06:44 PM
The wire is broken somewhere between C588 and G553. You can either locate the break and fix it or simply run a new ground wire and attach it to the chassis.
Old Feb 16, 2014 | 06:46 PM
69cuda340s's Avatar
Ron thanks so much for your help I'll trace it down...
Old Feb 16, 2014 | 06:47 PM
efiliated
Jun 5, 2011 06:02 PM
lmike6453
Feb 2, 2009 07:43 AM
DJ_SaNdOz
May 20, 2004 12:14 AM
xXx Justin xXx
18
Mar 21, 2003 03:01 PM
