Stereo doesn't work but 12v outlet does, no fuses blown.
Old Feb 16, 2014 | 02:04 PM
B_Swapped93's Avatar
Default Stereo doesn't work but 12v outlet does, no fuses blown.
94 GSR
I'm at a loss as to why my stereo doesn't work any more I checked any related fuses all good even the little one on the back of the unit it's self. According to the under-dash fuse box the radio and cig lighter are connected so in theory it should be down also but it's not. Will just ditch the stereo/speakers if it can't be fixed but I'd like to have it.
Old Feb 16, 2014 | 02:09 PM
fcm's Avatar
fcm
Old Fart
Default Re: Stereo doesn't work but 12v outlet does, no fuses blown.
If you have both the powers, 12V+ constant abd 12V+ acc. and a ground and unit still will not work, the HU is N/G. 94
Old Feb 16, 2014 | 03:01 PM
Originally Posted by fcm
the HU is N/G. 94
is there a way I could test it(stereo) ? i'd like to not have to buy a new one just to see, I have one out of my old civic but the plug won't fit for some reason they're both pioneers.
Old Feb 16, 2014 | 03:22 PM
collkid's Avatar
Sure. I had to do this in my Jeep.
Just run direct wires from the battery to the stereo and see if the deck turns on. If it does, its your wiring, if it doesn't, its the deck.
Old Feb 16, 2014 | 05:17 PM
as in when the key is in the I position and II(acc) ? I just stopped working that's what confuses me. i'll be splitting the loom a bit more and see if I nicked something important, the previous owner didn't really use a plug n play harness it's just twisted in and covered in electrical tape. Also going to take a test light to the 12v and 12v ACC just to confirm I'm getting power if not well i'll try n trace it there not much as far as wiring left in the dash any more save from my blinkers,hazzard, dash dimmer and the cluster plugs.
singlecamslamed
Apr 9, 2011 10:49 AM
fernando.
Apr 6, 2010 11:48 PM
x4and3r1991
Sep 19, 2008 08:45 PM
teddy_dc2
Audio / Security / Video
Aug 20, 2006 07:20 PM
Truecure
Aug 26, 2005 08:22 AM
