1993 honda accord lx starting issues please help dianose problem
Old Feb 16, 2014 | 12:44 PM
dude71853's Avatar
Icon2 1993 honda accord lx starting issues please help dianose problem
hello my name is wayne i have a 1993 honda accord that does run when it wants to in the mornings you can hear the fuel pump running but after awhile of driving the car after it gets warm it doesnt start when you turn the key over you dont hear the fuel pump while turning it over when this happens i have to let the car to sit five minutes then after that it will start can you all tellme what i can do to fix this problem im thinking its the fuel pump or do you all think it something else please let me know please
Old Feb 16, 2014 | 01:23 PM
larbabe's Avatar
Default Re: 1993 honda accord lx starting issues please help dianose problem
Fuel pump quick test... disconnect the line where you can and turn the key briefly. If it spurts it works.
Old Feb 16, 2014 | 04:47 PM
dude71853's Avatar
do i disconnect it from the fuel rail at the injectors because im askking there no quick disconnect there its bolted in by a bolt do i remove it from there when it tries to do it again
Old Feb 16, 2014 | 07:02 PM
larbabe's Avatar
I'm sure there's a better way to do this, and some of the folks here would know best. I don't think it matters where along the main line you check. Just remember if the pump is working you'll be spraying gas and that's a setup for disaster if you're not really careful. When I did it I clamped a piece of hose on the line and put it in a container away from the car. Would be good to do a search and see what other advice is out there.
Old Feb 16, 2014 | 08:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Check the main relay, if you do not hear the pumps come on after the car warms up either from a trip or being in the sun the Main relay may be going bad. It is located in the dash.
Click on the 'techauto' link in my sig and go to the MAIN RELAY section.
Old Feb 16, 2014 | 10:41 PM
holmesnmanny's Avatar
We need to know if the car actually cranks or does it crank but doesn't start ?
Michele Walker
May 24, 2018 04:30 PM
CanadianAccord1
Mar 27, 2016 11:01 PM
nichole82
Mar 28, 2012 08:30 AM
ezeas123
Nov 10, 2008 07:49 PM
BSTDCG5
Classic Hondas
Jul 7, 2008 03:12 PM
