91 integra with b20b swap
Old Feb 15, 2014 | 05:30 PM
jdmb18b1flip's Avatar
Default 91 integra with b20b swap
Ok Honda tech need a lil help last night my Integra started idling really high like 3000 and that's after I was driving for like 45 min then today it did it again on my way home from work but it started over heating also and then my check engine light came on and now it won't rev past 3200 rpm checked the codes it's shooting code 6 for the Ect sensor my ???? Is could that one since do all that
Old Feb 16, 2014 | 08:50 AM
Pimptegr4's Avatar
Default Re: 91 integra with b20b swap
Im not so familiar with the b20b but my friend ran into the same issue on is ls/vtec and it was the ect switch the issue in his case.
Old Feb 16, 2014 | 09:05 AM
B_Swapped93's Avatar
relative cheap to replace check for any vac leaks tho just in case I've never heard of it causing a high idle.
Old Feb 16, 2014 | 11:01 AM
I've replaced the ECT sencer ND its still doing the same thing ND shooting the code but I cheaked ND there is no power runnng to the plugs
keslerbuilt
Oct 27, 2013 07:56 PM
Boost305
Feb 14, 2012 06:17 AM
integra*LS*
Apr 14, 2008 06:32 AM
91DA951
Sep 8, 2007 11:17 PM
civicb16eg
Oct 26, 2006 03:11 PM
