Idle Hunt problem
Old Feb 15, 2014 | 04:23 PM
Ef4doorwagon's Avatar
Default Idle Hunt problem
Just did a mpfi swap on my ef, car runs fine, except for it idle hunts ( idle jumps from 1 and a half down to about 500) and its really anoying. I changed the iacv, cleaned it with carb cleaner untill all the carb buildup went away, not sure what it is. Ive heard something about the fitv idk where its at exactly, but if its the part tht sits ontop of the throttle cable and next to the tb, then im screwed cuz all the tiny screws are stripped. Any help is greatly appreciated.
Old Feb 15, 2014 | 09:49 PM
jonGSR's Avatar
Default Re: Idle Hunt problem
Check for leaks from the intake manifold gasket.
Old Feb 15, 2014 | 10:30 PM
ghosthatch's Avatar
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
vacuum leak or fitv. its on the TB
Old Feb 15, 2014 | 11:40 PM
Whats the best way to check for leaks?
And do single cam engines come with fitv? More specifically does the a6 manifold have it? Cuz i clicked that link and in the picture it has it under the tb, but my tb has nothing under it that looks like that
Old Feb 16, 2014 | 07:41 AM
ghosthatch's Avatar
the a6 doesnt have a fitv. you can check for leaks by spraying carb cleaner while its running. if the idle surges while youre misting it around you have found your spot. or you can do a smoke test
Old Feb 16, 2014 | 12:06 PM
Thx for the info ghost, i didnt find any leaks while using carb cleaner, but i did notice the pcv hose disconnected from the breather box, idk if this might have caused an air leak. I
CRX_RR
15
Sep 21, 2008 05:14 PM
luv2boost
Jun 2, 2008 06:33 PM
PhilMac
Jan 14, 2008 11:35 AM
BME1986
12
Jul 13, 2004 04:57 AM
QWKPHKR
Aug 11, 2002 11:35 AM
