damn obd0 crap screwing me again
Old Oct 28, 2002 | 11:40 PM
smashed4thgen's Avatar
Default damn obd0 crap screwing me again
here is my prob
my canf obd0 dpfi
my engine (swap ) is obd1 mpfi
iam planning on goin turbo and i know if i use obd0 stuff like dizzy injectors and ecu it will work but how will the injectors go in if there obd0 or not to work with a obd0 ecu(not physicly but electricly) or is there another /better way to wire this thanks
Old Oct 29, 2002 | 12:23 AM
SEA Hag's Avatar
Default Re: damn obd0 crap screwing me again (smashed4thgen)
You can re-wire your car to OBD-1. You will still have to convert it to mpfi, but i dont think you will need a resistor box. You should do a search.
ps. I have only done the obd 0 dpfi to mpfi swap in my 90 dx, with a D15b7 and auto
Old Oct 29, 2002 | 12:28 AM
Default Re: damn obd0 crap screwing me again (SEA Hag)
search sucks it didnt help me much at all thanks though
Old Oct 29, 2002 | 03:04 PM
SEA Hag's Avatar
What kind of engine swap do you have, and what kind of car do have?
Old Oct 29, 2002 | 03:09 PM
Booger's_Rex's Avatar
need a few more things like car and what swap you are doing to help you. and why switching from obd0-1. then i can give more help
Old Oct 29, 2002 | 08:51 PM
Default Re: damn obd0 crap screwing me again (Booger's_Rex)
90 std hacth to 93 teg motor
Old Oct 29, 2002 | 08:52 PM
so i can use the existing pieces i have because iam broke /all my money goin to boosting it
Old Oct 29, 2002 | 09:03 PM
YumVTEC's Avatar
wow, that's the same thing i'm doing to my wife's car. 90 std hatch to 92 b17a.
here's our plan, and i think it may help you:
use the std. engine harness, but splice in the injector plugs (basically convert it to MPFI without the resistor box, since we're using the b17a obd1 injectors and ecu), alternator plug, and distributor plug from the obd1 harness. then run wires for knock, vtec, 4-wire o2 sensor, into the cabin through the firewall.
make (or buy if you're not adventurous) a obd0 --> obd1 ecu harness jumper, and plug in the b17a ecu, then connect up the few extra wires coming through the firewall to the few extra on the ecu jumper harness.
boom, done. obd1 in a pre-obd car.
[Modified by YumVTEC, 6:05 AM 10/30/2002]
Old Oct 30, 2002 | 11:03 PM
Default Re: damn obd0 crap screwing me again (YumVTEC)
thanks your the first person to actualy awnser this question
your a bad ***
thanks
mike
Old Oct 31, 2002 | 07:44 AM
YumVTEC's Avatar
you're welcome. in theory it should be easy, i guess i'll find out how truly easy it is when I actually do it myself. let me know how things go for you.
-Trevor
NWHybrid
15
Nov 10, 2016 08:11 AM
knoklu
Jul 2, 2009 11:07 AM
birdricer
May 9, 2007 05:36 PM
solohatch
Jul 1, 2005 12:13 AM
