90 CRX Manual stick adjustment
Old Feb 15, 2014 | 12:20 PM
richs90crx's Avatar
Default 90 CRX Manual stick adjustment
I just happened to stumble upon a CRX for free. After a new battery and a air control valve she should be purring like a kitten. One of the issues is when its in gear 1-5 and in reverse the sloppy loose almost like it's in neutral. Is there any adjustment I can do to get the slop out of it? Any help would be greatly appreciated. Thanks in advance!
Old Feb 15, 2014 | 01:17 PM
ProjetEF's Avatar
Default Re: 90 CRX Manual stick adjustment
i would first check the shift linkage bushing ( under the car, over the exhaust line, where is the shifter mounted at.
If these are good than it might be in the transmission
hondachris1994
May 13, 2011 02:45 AM
dhatcher2002
Nov 21, 2008 03:26 PM
Ironxcross
Oct 9, 2007 06:01 PM
vtec95
May 23, 2005 08:20 AM
DaMmniTz
Nov 14, 2004 11:02 AM
