How to tell if f20b is manual or auto motor
Old Feb 15, 2014 | 10:56 AM
Joshyboy2929's Avatar
Default How to tell if f20b is manual or auto motor
There is no vin on this f20b I'm about to buy, but I need to make sure it's the manual version.
There is the f20b stamp and under it reads 2703301
All help is appreciated thanks!
Old Feb 15, 2014 | 12:12 PM
GhostAccord's Avatar
Default Re: How to tell if f20b is manual or auto motor
Why does it need to be the manual version? Only difference was a difference in lift and duration on the cams and the ECU. All the parts still bolt up the same whether they are Manual or Auto.
Sorry I can't answer your question about how to tell the difference from the outside. Hopefully someone else can help.
Old Feb 15, 2014 | 01:29 PM
Yea you just kinda answered your own question, it matters because of performance purposes. Thanks though
Old Feb 15, 2014 | 05:08 PM
You realize that what you are talking about might be a 10whp difference. I realize that 10whp is 10whp and it's better than nothing, but I wouldn't loose any sleep over the difference.
What price do they have it listed at?
Old Feb 15, 2014 | 05:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Well, does it have a flywheel or flexplate(driveplate) on the back of the crank?
Outside of measuring the cams, AFAIK, there are no tell tale differences between an MT and AT F20B.
Someone mentioned that Honda may be able to decipher those non Vin numbers off the block, but I have no idea if that is true.
Old Feb 15, 2014 | 05:44 PM
Mishako129's Avatar
I was about to say the same thing. Also look at the TB rotor, if its for manual or auto, and also the halfshaft on the back of the block, is it there or not?
The TB diameter is also larger with the MT, so measure that too.
Old Feb 15, 2014 | 11:13 PM
holmesnmanny's Avatar
You have two options. Provided the block has a vin you plug that into any online Honda dealer and it will give you part options. If the options include a clutch then it's a stick.
Options two is to look at the throttle body. The auto will have two slots, one for the throttle cable and another for the kickdown cable.
Old Feb 18, 2014 | 06:43 AM
Yea the vins been rubbed off and it's not using the stock tb it has a h22 tb so I'm kinda stumped
Old Feb 18, 2014 | 02:43 PM
some options in the thread u posted in the prelude forum
Old Feb 18, 2014 | 02:48 PM
actually hmotors guarantees all sensors working so im curious why it wouldnt have a stock throttle body ... does it have an f20b engine stamp ? also auto and manual tb's are easily distinguishable from each other ... take a pic of the tb let us see the tb
hondacivic09
Honda Civic (2006 - 2015)
11
Jan 6, 2010 08:22 AM
WNYAccordLX
Jan 15, 2005 02:31 PM
CRX_Control
Aug 30, 2004 05:20 AM
Sinner
Aug 26, 2004 12:44 AM
