CTR cams, skunk2 sprockets, and new timing belt.... wierd "supercharged" noise....
Old Oct 28, 2002 | 11:34 PM
Unsung's Avatar
Default CTR cams, skunk2 sprockets, and new timing belt.... wierd "supercharged" noise....
CTR cams, skunk2 sprockets, and new timing belt went in today. Now the car makes a whining supercharged noise from the timing belt area... any ideas?
Old Oct 29, 2002 | 02:23 AM
b19coupe's Avatar
Default Re: CTR cams, skunk2 sprockets, and new timing belt.... wierd "supercharged" noise.... (JDM B-Series
You may have the belt too tight. I actually prefer my timing belt to sing a little, loose belt = problems (but is quiet).
Old Oct 29, 2002 | 07:11 AM
WAFFLES's Avatar
sounds like the belt is too tight.
Old Oct 29, 2002 | 11:42 AM
EKhatch's Avatar
That's about the only thing I can think of!
Old Oct 29, 2002 | 01:49 PM
Katman's Avatar
either too tight or the belt is rubbing on the plastic timing belt covers somewhere.
Old Oct 29, 2002 | 01:57 PM
obd2gsr's Avatar
right on the money... check to see if they put back your timing belt cover, because w/o it, it will make a slight whinning noise.
Old Oct 29, 2002 | 02:19 PM
skunked's Avatar
I don't think it's to tight. check the belt for iregular wear caused from the belt rubbing on the plastic covers. The belt is not creeping over on the sprockets is it?
Old Oct 29, 2002 | 03:29 PM
Passaudi1.8t's Avatar
New User
My old Civic did the same exact thing when I had an AEM cam gear and a new timing belt installed. I believe it has something to do with belt tension and the fact that the grooves for the belt on the cam gear are slightly different shaped for better grip i assume... anyway, the noise slowly went away after a while, don't sweat it.
Old Oct 29, 2002 | 04:45 PM
blackEF's Avatar
yeah jake....the zc timing belt whines too...when do i get a ride in the si?
Old Oct 29, 2002 | 05:08 PM
blackEF's Avatar
Old Oct 29, 2002 | 10:31 PM
Unsung's Avatar
dude your gonna love it barry... i tuned the cam gears some more... pulls really hard.
airikkCRX
Apr 2, 2010 08:29 AM
SPIKE'S91CIVICSI
Mar 9, 2009 03:11 PM
Osis
Honda Civic (2001 - 2005)
Oct 15, 2007 08:23 AM
obd2gsr
Dec 21, 2002 08:53 PM
nerdish
Jul 17, 2001 11:22 PM
