Suspension & Brakes Theory, alignment, spring rates....
Si/SiR e-brake cables the same as DC integra one's ?.
Old Feb 14, 2014 | 06:45 PM
B_Swapped93's Avatar
Default Si/SiR e-brake cables the same as DC integra one's ?.
Can get both the e-brake cables for the Si/SiR for 65$ from the Honda dealership, but will the fit the 3rd gen integra ?. They may be cheap at Acura too but the web page says they're 90$ a cable.
thx
Old Feb 14, 2014 | 07:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Si/SiR e-brake cables the same as DC integra one's ?.
Hate that, looking at the sway bar bolt from the 97 Integra, at Acura it was almost 8 dollars a bolt and the exact same part number at Honda was under 7 bucks a bolt....
Hopefully the Honda one's work for you. Do the part numbers match between Acura and Honda?
Old Feb 16, 2014 | 07:20 AM
94EG8's Avatar
Seagull Management
They're different. I think you can make them fit, but they don't fit the way the correct cables do.
Old Feb 19, 2014 | 06:10 PM
Hmmm ok don't ppl use the integra e-brake cables for rear civic disc swaps tho ? I'm not worried if the line mount tabs bolt up more that there is adequate tension so it works properly.
thx
__oversea
Dec 7, 2009 05:51 AM
ron_logic
May 22, 2009 03:40 AM
db8teg209
Dec 21, 2007 04:42 PM
Cashieboi
10
Jun 10, 2005 05:39 AM
kingalidaei
Dec 7, 2004 07:31 AM
