97 EK GSR SWAP clutch problems
Old Feb 13, 2014 | 08:52 PM
mr_romero91dc2's Avatar
Default 97 EK GSR SWAP clutch problems
hi everyone, I'm new to the site but have used this site for many troubleshooting problems. I currently have an issue with this new car. Its a 97 Ek coupe, with a gsr swap. We swapped the swap from a ej1 (perfect running condition). The swap went in easy enough but now I'm dealing with a clutch pedal that has no pressure. The clutch is a competition stage 4 with only about 600 miles on it (worked perfect on the ej1). Replaced the CMC and the slave cylinder, along with the whole clutch line. I've taken the steps to bleed it and still no pressure. Any ideas or input will be greatly appreciated.
Old Feb 13, 2014 | 09:29 PM
ej1b18c1's Avatar
Default Re: 97 EK GSR SWAP clutch problems
Seems like the CMC has a crap load of air in the system or you have a leak somewhere. How many times have you bled the system?
Old Feb 14, 2014 | 06:08 AM
kyden's Avatar
is the slave cylinder moving?
Old Feb 14, 2014 | 09:32 AM
bled I a **** load of times man, still no pressure
Old Feb 14, 2014 | 09:33 AM
no, its not moving at all. The only coming out of it is air and little sputters of fluid
Old Feb 14, 2014 | 09:48 AM
kyden's Avatar
is the rod adjusted correctly?
Old Feb 14, 2014 | 10:05 AM
yeah rod is adjusted correctly
Old Feb 14, 2014 | 10:50 AM
ej1b18c1's Avatar
I wonder if the throw out bearing is installed correctly
Old Feb 14, 2014 | 10:56 AM
I did the clutch myself when the swap was in the ej1, I bled it once and boom perfect shifts. when I did the swap in the new shell I didn't separate the trans from the long block so I don't see there being an issue internally.
Old Feb 14, 2014 | 12:17 PM
carlos8's Avatar
Since you have all new, MC, SC and line. Like Kyden said are you sure the rod is pushing the piston all the way?
If you are sure, then you need to perform manual tests. Sometimes things come defective, That's why always is good to charge the MC out.
Bench test the MC with a screwdriver, if is good then blow the line with air connect the line to the MC and repeat the test, If all is good install it again and test the rod travel. Bleed it again if not bleed you only have one thing left SC.
Ek9b20v
12
Mar 31, 2013 01:21 PM
nitro911
Jun 17, 2011 06:05 PM
FO SHO
Transmission & Drivetrain
May 25, 2011 09:22 AM
kra4718
Aug 1, 2008 05:57 PM
wadecarter89
Dec 23, 2006 08:10 PM
