jdm h22a won't rev past 3500 rpms
Old Feb 13, 2014 | 05:44 PM
bigmaccrew's Avatar
Default jdm h22a won't rev past 3500 rpms
I have a 97 civic ex with jdm h22a and lsd tranny with p75 ecu. All the sudden my speedo stopped functioning and my car won't rev past 3500rpms limp mode I guess. Cannot figure it out any ideas? Thanks
Old Feb 13, 2014 | 09:51 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: jdm h22a won't rev past 3500 rpms
Check the wiring to the VSS, check the VSS, take it apart make sure it is clean.
Old Feb 14, 2014 | 02:02 AM
holmesnmanny's Avatar
$15 dollar vss's all over ebay and amazon...easy to install
Old Feb 14, 2014 | 03:00 AM
Fliptard's Avatar
First off, you need the correct ECU to run an H22, a p75 is for an LS and will not work right. You need a P13 ( I believe) ecu.
As far as not going passed 3500, usually that's a bad TPS sensor.
Old Feb 14, 2014 | 05:27 AM
any number of sensors will throw the car in limp mode not just one
bigmaccrew
Feb 17, 2014 03:59 PM
accord-lude
Nov 10, 2004 09:15 AM
95accordh22a
Nov 5, 2004 02:03 PM
95 integra
Oct 10, 2004 06:17 PM
94gsrsedan
Jul 13, 2004 06:03 PM
