Rhd brake booster/brake problem
Hello everyone I don't usually get on here alot. But I currently converted my R to RHD and so far I'm having issue with my brake. If I was to drive for 5 mins my brake in my car will slowly stiffen and get hard as hell. I would be at a constant speed of 60 and my R will slowly lose acceleration . I would have to pull over and release air pressure from both the brake booster and brake caliper. And once I do so my car will drive good again but yet slowly go through the same issue. I bled the brake and clutch and I'm still having trouble. I even change out the M/C and that didn't solve the issue ether.
Sounds like the adjustment between the booster and master is out too far pushing the piston down a touch when you bolt the master down. This won't allow the return of fluid in the system from the calipers back to the resivour.
