Euro Type-R (f20B) motor specs
Old Oct 28, 2002 | 10:49 PM
HotWheelz's Avatar
Default Euro Type-R (f20B) motor specs
We all know that a f20b is basically a strocked down version of the h22a.. but i'm wondering if it's really a 200hp motor or 220 hp motor.... (sites are confusing)
i'm also wondering if the ports on the head are different, and also injector angle as well as valve sizes, back cut, degree cut.. and also other factors such as tb size etc... also i'd like to know the official redline of this motor if this one would rev more than the h22a counterpart or not...
also i'm pretty sure it uses the Type-S floating pistons which will increase hp by friction levels and a better balanced crank and dampter assembly.. i'm wondering about the cams.. is it using stock jdm h22a cams or type-s cams... (or even different cams from the type-s) ... injector cc size, fpr etc...
any info would be appreciated.. thanx guys !!!!
atlplayer4life90
Jun 23, 2007 05:06 PM
NirVTEC
Mar 29, 2007 07:57 PM
StephenB
Oct 4, 2002 04:32 AM
