top end gasket set
Can anyone recommend a good gasket kit for the top end, since honda disconnected them for our cars?
Or should I just go with oem. But that would require buying them all induvidialy.. is there a thread that would have all the part numbers
shouldn't be too many. Intake/Exhaust Manifold, Valve Cover, Head Gasket. Not sure what others you'd need.
Also it should be the same as any other B Series Engine, so the gaskets are pretty much the same part numbers.
But then t stat, vtec solenoid , some others I might not remember. I just want to order it all at once so I can save on shipping from delray acura
rasinhell
Jan 24, 2005 09:44 AM
jbell
Jan 7, 2005 01:56 PM
