F/S ERL Built B18cR Short Block
Old Feb 13, 2014 | 12:27 PM
esco115's Avatar
Icon7 F/S ERL Built B18cR Short Block
As title states fellas, here are the Specs;
ZERO MILES!!!
This is a true B18c Type R Block (have proof).
Its been bored to 84mm. So its close to a 2. liter.
ERL Block guard and Sleeves
ERL Balanced and Blue printed crankshaft
CP Piston #SC7020 (9:0:1 Ratio)
Manley H-beam Rods #14026
ARP Rod Bolts #208-5403
ACL Race bearings
Honda OEM Oil Pump NEW
Honda OEM Rear Main Seal NEW
Honda OEM Water Pump NEW
Gates Racing Water Thermostat NEW
Cometic Headgasket NEW 84mm for the block
Every seal/gaskets on this block is OEM NEW, in all I have close to $4k in this block alone!
Asking price I will start at $2600obo + shipping + PP Fee.
THIS ISN'T A CHEAP BUILD KEEP IN MIND, my lost your gain.
(The pink liquid or spots is lubricant/anti rust.)
NO TRADES!!!
Old Feb 13, 2014 | 04:46 PM
$MIKE$'s Avatar
Default Re: F/S ERL Built B18cR Short Block
sweet block should go fast.
but 9.0 cr pistons is low
Old Feb 13, 2014 | 04:56 PM
esco115's Avatar
Originally Posted by $MIKE$
sweet block should go fast. but 9.0 cr pistons is low
Thanks, it's built for big HP but still streetable... Not intended for little boy hp ratings... Lmao
Old Feb 13, 2014 | 05:05 PM
AZ_CIVIC's Avatar
Nice, good deal on the block.
Old Feb 14, 2014 | 01:37 AM
glosssilver's Avatar
Hey is the the block been sleeve or just have a block guard ?
Old Feb 14, 2014 | 05:32 AM
esco115's Avatar
Both as it states on my post. Iron sleeves w/ the guard.
Old Feb 14, 2014 | 05:04 PM
$MIKE$'s Avatar
Hahah 9.0 is old school stuff I guess f you plan to run it on 89
Lol GLWS
Old Feb 14, 2014 | 05:30 PM
psi2high's Avatar
9.0 just requires more boost to make power. Still quality parts that will hold the power
Old Feb 14, 2014 | 06:57 PM
esco115's Avatar
Hahah 9.0 is old school stuff I guess f you plan to run it on 89 Lol GLWS
As stated in the post above this... This build is to make decent to high hp, no not on 89... It's not built to run your average t3/t4 snail...
Old Feb 16, 2014 | 01:12 PM
esco115's Avatar
Bump
Old Feb 16, 2014 | 04:35 PM
10sec4door's Avatar
Wow 9.1 is low for boost lol man throw 40 pounds at it and fill that cylinder up. Glws. I'm 8.8.1 making 650 at 20 pounds!
Old Feb 16, 2014 | 04:36 PM
10sec4door's Avatar
Originally Posted by 10sec4door
Wow 9.1 is low for boost lol man throw 40 pounds at it and fill that cylinder up. Glws. I'm 8.8.1 making 650 at 20 pounds! Stock sleeves
Old Feb 17, 2014 | 09:33 AM
NVMYSTI's Avatar
I would've been all over this if it weren't for the low comp rate
Old Feb 18, 2014 | 04:11 PM
Discosteak's Avatar
You guys are crazy. I'm at 700 hp and sub 30 psi on 9:1 comp ratio. GLWS OP That is a nice motor
Old Feb 18, 2014 | 05:14 PM
esco115's Avatar
Thank you sir, the way I see it is go big or go home (HP related). Lol
On another note SOLD!!!! BLOCK IS SOLD!!!!
tamparican
Apr 13, 2011 07:42 AM
ejcivicdee
Jan 27, 2008 03:20 PM
GiNuWiNe
Mar 15, 2006 09:32 PM
chris@allmotor.net
Jun 1, 2004 05:44 AM
chris@allmotor.net
Apr 20, 2004 12:40 PM
