98 Civic - Power locks, dome/map lights, and plate light not functioning
Old Feb 13, 2014 | 10:57 AM
Kappaklap's Avatar
Default 98 Civic - Power locks, dome/map lights, and plate light not functioning
This is with a 1998 Honda Civic EX Sedan. With the exception of the driver's side all of the power locks are not functioning, as well as the dome, map, and plate lights. I checked the bulbs and they seem fine, as well as the fuses. Is there a common issue that could be connecting all of these? I'm as new as it gets to these types of problems, so any help would be greatly appreciated!
Thanks!
Old Feb 13, 2014 | 11:03 AM
Former User's Avatar
Default Re: Power locks, dome light, map light, and plate light are not functioning.
Voltage test fuse 43.
Check for broken wires in the driver and passenger door jamb connectors.
Test the bulbs.
Old Feb 13, 2014 | 11:08 AM
Kappaklap's Avatar
Test the bulbs.
I'm currently looking in my manual diagram for fuse 43, but I'm not seeing anything. Could it be a different one by any chance?
Thanks again!
Old Feb 13, 2014 | 11:09 AM
Hood fuse 43 is for the dome, map, and trunk lights.
Old Feb 13, 2014 | 11:32 AM
Kappaklap's Avatar
Got the interior lights and taillight to work by switching out the fuses! Now I just need to tackle these door locks. What exactly will I be looking for? Frayed wires? How do I check for a grounding issue?
Old Feb 13, 2014 | 11:37 AM
Remove the rubber boot covering the door jamb connectors. Carefully check for broken wires.
Old Feb 13, 2014 | 11:38 AM
Kappaklap's Avatar
Can I do that with the door panel still on? Sorry for all of these rookie questions
Old Feb 13, 2014 | 11:39 AM
yes
Old Feb 13, 2014 | 11:57 AM
Kappaklap's Avatar
Just opened the passenger side and everything looks okay. However, I opened the driver side and there was a split in the boot midway that exposed the wires. I unclipped the boot and it seems like there was a wire or two in there that wasn't nearly in the same shape as the other ones. Although it was kind of hard to see. Is there a specific color wire that I should be looking at? Would the driver's side wire affect all the others except the driver's door? So how should I proceed now, take the door off the hinges and look for a bad wire and if I do see one, splice one in?
Old Feb 13, 2014 | 12:00 PM
Can you see the main color/stripe color of the wires?
Yes
Removal of the fender is probably needed to do the repairs. You'll also want to replace the boot.
Old Feb 13, 2014 | 12:10 PM
Kappaklap's Avatar
Yes I can
Old Feb 13, 2014 | 12:12 PM
Yes I can
Can you post them for the broken/damaged wires?
Old Feb 13, 2014 | 12:36 PM
Kappaklap's Avatar
I uploaded some photos, sorry, I used my phone so it's difficult to see anything. You can definitely tell though that's it's fairly "sludgy" in there and it may have corroded a wire or connection.
http://imgur.com/a/VntpH
Old Feb 13, 2014 | 12:38 PM
Yeah, picture is out of focus. What colors (main/stripe) are the damaged-looking wires?
Old Feb 13, 2014 | 12:46 PM
Kappaklap's Avatar
I had to clean some of the wires off with a q-tip, but I see a white wire/red stripe with a break in the outer casing.
Old Feb 13, 2014 | 12:50 PM
A broken Wht/Red wire would prevent the passenger doors from locking/unlocking but would not affect the driver's door lock.
Old Feb 13, 2014 | 12:53 PM
Kappaklap's Avatar
Great! So I'm on the right track haha! Is there somewhere I could see these wire color codes by any chance? So I'm guessing I should proceed then by removing the fender, clean that gunk that got in there from the boot being open, replace the wire (by splicing in a new one?), and then replace the boot?
Old Feb 13, 2014 | 12:56 PM
I'll post the circuit diagram.
Yep.
For bolded - Remove connector pin, resolder to Wht/Red wire, reinsert pin into connector.
Old Feb 13, 2014 | 12:59 PM
C556 shows the pin out of the door jamb connector:
https://honda-tech.com/forums/showpo...8&postcount=15
Here's the circuit diagram:
Old Feb 13, 2014 | 01:00 PM
Kappaklap's Avatar
Yep.
Awesome! That diagram would be useful. Anyway to do this without soldering? Not sure if I have a soldering gun laying about or not. If need be I'm sure I could pick one up/borrow one though.
Old Feb 13, 2014 | 01:01 PM
Soldering is a must. The wire generally breaks very close to the connector pin.
Old Feb 13, 2014 | 01:03 PM
Kappaklap's Avatar
Ah, okay no problem! After I get this done in the next few days is there anyway I could paypal you a few bucks for your time? Seriously, you should be compensated for this lol.
Old Feb 13, 2014 | 01:06 PM
Kappaklap's Avatar
Also, am I just cutting the bad part of the wire, then pulling it over and resoldering it? Or do I need to pick up more wire? If so, what kind?
Old Feb 13, 2014 | 01:17 PM
That's very kind of you.
Old Feb 13, 2014 | 01:19 PM
You'll pop the pin corresponding to the Wht/Red wire out of the connector and solder a short exposed section at the end of the Wht/Red wire to the pin. Then you just reinsert the pin (soldered to the wire) back into the connector.
