fuel pump takes forever to prime!!! help
Old Feb 12, 2014 | 07:42 PM
gamajohn's Avatar
Default fuel pump takes forever to prime!!! help
Ok I've seen this thread a few times already but it seems the problem was never resolved. I'm having this problem now. My 91 civic takes a few min before the fuel pump will prime then I can start the car. I have 4 main relays which I switch back and forth to see if that's the cause but they all do the same thing. I got them from the junkyard by the way. Also the car will die randomly while I'm driving it but then I can start it right up. Sometimes even when it primes it won't start after that and i have to wait 25 min before i can drive it again. Fuel pump is new. Any ideas. It's not running any codes too. It did this once before but worked itself out.
Old Feb 12, 2014 | 08:13 PM
instrument's Avatar
Default Re: fuel pump takes forever to prime!!! help
have you checked that its getting power? did you replace the strainer?
if youhve power on key turn at the pump would seem the pump is the issue.. being new doesnt really mean much.
Old Feb 12, 2014 | 08:16 PM
Former User's Avatar
Sounds like a bad ECU.
Old Feb 13, 2014 | 08:13 AM
gamajohn's Avatar
Well is there an easier way to test if it's getting power other than dropping my gas tank again?
gamajohn's Avatar
A few people told me that could be the problem
Old Feb 13, 2014 | 08:17 AM
It's a common problem for aging ECUs. Swap in a known good ECU to see whether the problem is eliminated. Can you borrow an ECU from a friend?
Old Feb 13, 2014 | 08:29 AM
4drEF's Avatar
Keyboard Humorist
Sounds like maybe an intermittent ground at the thermostat housing.
Old Feb 13, 2014 | 08:48 AM
gamajohn's Avatar
I thought that too. I've checked all of them and the wire harness is from swapshopracing so I hope it's not messed up but I doubt it
Old Feb 13, 2014 | 08:49 AM
gamajohn's Avatar
It's a p28 ECU. I don't know anyone with a manual p28. So the fuel pump taking a long time to prime is a common sign of the ecu going out? Also the car when warmed up idles crazy now. Up and down
Old Feb 13, 2014 | 08:56 AM
What engine?
Any 92-95 Civic OBD1 ECU, either auto or manual, would be fine for testing purposes. You just need to verify that the fuel pump primes immediately and every time you turn the key to ON(II).
Yes, the symptoms are a perfect fit with a bad ECU.
Could be a related or separate issue.
Old Feb 13, 2014 | 09:41 AM
gamajohn's Avatar
What engine?
Thanks a lot man ill give that a try then
Ya I figure tps... or now maybe the ecu lol
Old Feb 13, 2014 | 09:42 AM
gamajohn's Avatar
Ok cool thanks a lot I'll try a different ecu and see if that's the problem
Old Feb 13, 2014 | 09:53 AM
...or dirty IACV, dirty FITV, air in cooling system, vacuum leak, air intake leak...
Old Feb 14, 2014 | 09:33 AM
crazyhouse2011's Avatar
I can ship you my p28 ECU at a cost of 100 dollars a day not in my possession to make up my losses at work. For testing purposes you can use the ECU for 24 hours, then ship it back in a postage paid box (included in original shipment). There are a few guidelines:
1. You cannot open the ECU under any circumstances.
2. You cannot steal the ECU.
3. You cannot damage the ECU.
4. In the event of a damaged ECU, you will replace it at your expense.
5. Payments will be issued via paypal or cashier's check.
Let me know OP if you need my ECU.
Old Feb 14, 2014 | 09:36 AM
crazy -- I assume you are not acquainted with the PM feature.
Old Feb 14, 2014 | 09:43 AM
4drEF's Avatar
Keyboard Humorist
$100 a day.
How much do you charge to fly out, install, and tun the key?
Old Feb 14, 2014 | 09:46 AM
$100 a day.
crazy is a high end ECU prostitute.
Old Feb 14, 2014 | 10:41 AM
Sorry, replied to the wrong poster lol
boost16awd
10
May 19, 2017 10:21 AM
rupensane
14
May 16, 2009 12:28 AM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
deca
Dec 13, 2005 10:50 PM
wpgcivic
Dec 7, 2004 05:44 PM
