immobilizer problem EK4 - can't get car to start
Old Feb 12, 2014 | 08:47 AM
RinzEG6's Avatar
Default immobilizer problem EK4 - can't get car to start
hi,
I got a problem with the factory immobilizer of a EK4 civic.. The immobilizer does not respond to he central locking anymore, so I cant get the car to start. I checked the fuses and noticed it was on the same fuse as the sunroof. So after sliding the sunroof in and out the immobilizer responded! This worked once.. (maybe just a coincidence) I tried both of the central locking buttons but it simply doesnt respond..
Old Feb 12, 2014 | 01:46 PM
tony_2018's Avatar
Fish Twig
Default Re: immobilizer problem EK4
ukdm correct?
edit: if so than you should've gotten a red key with the car to help with the reprogramming. If not than you will need to either remove the immobilizer or bring it to the dealership to reprogram the key.
Old Feb 12, 2014 | 02:00 PM
B_Swapped93's Avatar
worn out battery ? you're talking about the little fob on a keychain right ?
Old Feb 13, 2014 | 03:20 AM
RinzEG6's Avatar
Originally Posted by tony_2018
ukdm correct?
Its a EUDM, But I do got a red key! This morning I got the car to start once.. It responded only the first try. After driving it for a while it once again didnt respond anymore. How do I use the red key for reprogramming?
Thanks
Yes, batteries are good!
Patryk619
11
Jul 7, 2015 07:45 AM
xNOPEYx
14
Apr 6, 2014 09:30 PM
tran1088
Acura TSX
Jan 19, 2012 11:51 AM
ylor4
Nov 14, 2008 09:02 PM
Serdar
Oct 7, 2003 04:27 PM
