Gram Lights 57Pro valve stem
Old Feb 11, 2014 | 07:33 PM
RICE POLICE SIP's Avatar
Default Gram Lights 57Pro valve stem
I've got a set of these wheels and one of them is leaking at the valve stem... Anyone know where I can get a replacement... I found one for about 30 bucks but before pulling the trigger, I'd like to see if anyone knows of either a local shop or a site that has them for a more reasonable price? Really just need the grommets if they sell them individually....
This is the style of valve stem i'm looking for..
These are the wheels... it's a 90 degree valve stem which is 2" long or 55mm...
Any help would be greatly appreciated!
Shane
Old Feb 11, 2014 | 08:26 PM
toyomatt84's Avatar
Sanji
Default Re: Gram Lights 57Pro valve stem
They're a standard wheel valve stem. The brand doesn't make them anything special, in this case. Just order up some standard bent valve stems, as they will function fine.
Old Feb 11, 2014 | 08:30 PM
I haven't been able to find ones that are the same length... Either quite a bit shorter or quite a bit longer which of course would make them sit to far in or protrude out some... Also this is a bad pic because it shows a standard valve stem.. Mine actually sits inward.. i'll try and find a better pic
Old Feb 12, 2014 | 07:32 AM
Bump
Old Feb 12, 2014 | 03:21 PM
toyomatt84's Avatar
Sanji
Scroll down the page here: http://www.upgrademotoring.com/wheel...ccessories.htm
Old Feb 13, 2014 | 08:02 PM
Thanks ^^^ I was able to find this site... I haven't received them yet but they should work out.... And much cheaper..
http://shop.wheelflip.com/collections/valve-stems
dpine
Jun 10, 2017 06:32 PM
soiii
Mar 9, 2011 10:15 AM
totsie7944
Feb 22, 2009 01:49 PM
phish4709
Mar 16, 2007 05:01 PM
