Addco Rear Sway Bars 3/4"
Hey there I have a 95 Acura Integra Special Edition Coupe and I was wondering if these Addco sway bars would fit and work on them? Or would I be better off with Eibach sway bars?
You didn't prove links, but that's beside the point if you're going with anything over the stock 14mm a sub-frame brace is needed, ASR or if you have extra to spend function 7 both make great ones. As for the sway bar an ITR would be fine for DD or light track use. I've got a 32mm hollow bar on order.
CanadianEJ2
Suspension & Brakes
Sep 22, 2014 07:08 PM
Si Arn
49
May 3, 2004 09:59 PM
