dpfi d16zc running
I just bought a d16y7 block with a z6 head in a white ef sedan it is dpfi and is running but the idle is very low and I feel its because the distributor only one bolt lines up so im wandering what DISTRIBUTOR should I use on this setup?i believe it has the d15 distributor right now on the d16zc
Here is a helpful post from the past:
I think it is a complete waste to run your combo in DPFI setup so you might want to consider upgrading to MPFI and converting to OBD1.
Here is a successful mini me summary taken from D-series forum:
check the #'s on them
[TD-01] Civic/CRX DPFI 1988-1991
[TD-02] Civic/CRX MPFI 1988-1991
[TD-03] OBD0 DOHC ZC Civic/CRX 1988-1991
[TD-22] OBD0 B16 Civic/CRX/XSi 1988-1991
[TD-23] OBD0 B18a Integra 1990-1991
[TD-31] Accord 1990-1991
[TD-41] Civic D15b Non-VTEC 1992-1995
[TD-42] d16z6/d15b VTEC 1992-1995
[TD-43] OBD1 DOHC ZC 1992-1995
[TD-44] OBD1 B16/GSR/ITR VTEC 1992-1995
[TD-46] OBD1 b18a/LS/B20/CRV 1992-1995
[TD-52] Accord 1992-1993
[TD-55] OBD1 b18a/LS/B20/CRV 1992-1995
[TD-60] Prelude H22a 1992-1996 JDM
[TD-63] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
[TD-68] OBD1 B16/GSR/ITR VTEC 1992-1995
[TD-73] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
[TD-84] OBD2 B16/GSR/ITR VTEC 1996-2001
[TD-89U] Prelude H22a 1997-2001 JDM
anyways, i got it running good(except for still missing the z6 dizzy, which will be coming)...
to get it to run right, i have the y7/y8 crank gear for the timing belt, y7/y8 timing belt, z6 cam, y7/y8 cam gear, and now it runs normal n is drivable.
it is OBD-1 converted using a virgin P28 ECU.
^That successful mini me summary may not be 100% applicable considering that the OP's setup is technically a VTEC conversion and not a mini me (specifically the use of the Y7/Y8 cam gear).
OP - The reason why your distributor is only being held by one bolt is because the D16Z6 head has it's one unique distributor flange pattern only shared with the D15Z1 (and a few ZC/D15B heads that are based on the same design/casting). It probably is the correct distributor to use with the ECU but probably is being limited in terms of adjustment.
Also as "radex7" touched on, you aren't really taking advantage of what you have because you're two fold on restraints. Not only are you not able to use VTEC but you have the DPFI setup. I'd absolutely back "radex7" in suggesting at a bare minimum doing the MPFI conversion.
Victor Jónsson
Apr 23, 2016 07:26 AM
