built dart b20 tall deck fs
Call text (615)870-9796
Located in Portland TN
brand new dart block 85mm
JE 9:1 pistons Calico Coated CT-2 Thermal Barrier Coating - Silver on Piston Tops and CT-3 Dry Film Lubricatig Coating On Piston Skirts
Eagle 5.967" rods
Eagle 95mm knife edged forged and balanced crankshaft
Calico coated rod and main bearings
Full rotating assembly was balanced with the flywheel and stock balancer that's included
brand new p72 Honda oil pump and mounting bolts
brand new Honda oil dipstick tube and dipstick
Had a machine shop known for building race engines in Nashville build the bottom end. Shacklett machine. They had to line bore the block and resize the rods for proper bearing clearances. Machine shop said the piston sticks out .021" and a .071" or thicker should be used.
Don't have the oil pan, pickup tube, or windage tray. Other than that its a complete shortblock.
$3500 for shortblock
have a built b16 head with endyne port job ferra valves itr cams that can go with it for 4200 as a package. This engine should make well over 600
Eagle 5.967" rods
those are actual photos. I don't have assembled pics because the engine is at my friends climate controlled garage. If you are interested in other pics text me and Ill find the time to go take a few.
I'm going to wait on selling the head till I make sure the bottom end is sold.
its a complete short block now. Just bought oem windage tray, pickup tube, water pump, water tube and neck, and all oem bolts.
Also a moroso 4.5 quart oil pan with return and oil temp bungs welded in.
