Steering Rack/Tie Rod
Old Feb 10, 2014 | 01:41 PM
relentlesstech's Avatar
Icon2 Steering Rack/Tie Rod
When I replaced my sway bar bolt/bushings, I noticed that the ball end of the tie rod (to steering rack) has a small amount of play to it - Does this mean I need to replace the entire steering rack, or can I get just the tie rod w/ball?
Old Feb 10, 2014 | 01:55 PM
94_civic_dx's Avatar
Default Re: Steering Rack/Tie Rod
u should be able to just replace the tie rod inner and outer then get an alignment
Old Feb 10, 2014 | 02:02 PM
I looked at a couple of kits for inner/outer tie rods, but none have the ball at the end that goes into the rack - When I pulled on the tie rod the ball moved out and in about 1/4 of an inch
Old Feb 11, 2014 | 01:34 PM
ya u need a new inner tie rod that ball is connected another part that screws into the rack
Old Feb 11, 2014 | 01:44 PM
B_Swapped93's Avatar
Yup^ just helps if you have this tool to do it. It's 50$ and well worth it comes with other attachments so you can use it on other car's.
Old Feb 11, 2014 | 01:46 PM
Thank you so much! I was looking at the prices for a new steering rack, and almost **** myself! It's a hell of a lot cheaper to get just the inner rods LOL
Old Feb 11, 2014 | 01:50 PM
just make sure to mark it with something so you can get the alignment some what close to what it was but make sure to get a alignment after u change the inners
i didnt even know they had a tool for them i always used a correct size wrench lol
Old Feb 11, 2014 | 01:56 PM
My integra used to be hellafush so underneath space was limited, this allows you to work outside of the wheel well, has a 1/2'' drive female coupler at the end.
Old Feb 11, 2014 | 02:02 PM
ok i will have to order one since i kno the parts store dwn here in the keys does not carry it
Old Feb 12, 2025 | 09:24 PM
Lilred.1's Avatar
You can certainly do just one if that's what you want to do.im the since we are here proved i can afford to do both I'm the both is better type chick. I'm like that about brakes tires steering parts spark plugs and spark plug wires. Like doing it that ways so that the next time there is a issue i i can say with relative certainty the thing i know it's not because i already fixed that thing. Besides if one gave out the other ain't far behind and this way u know where ur Gina be changing it and that u have the tools and it didn't cause a wreck or nothing.
theEFkid
Oct 16, 2013 05:43 AM
dr_latino999
Dec 6, 2007 12:22 PM
Charri
Oct 18, 2007 03:28 AM
Rywire
Sep 25, 2004 02:44 PM
TodaCivic
Jun 9, 2004 02:25 PM
